New TEAM WAVE racing brushless system
#1622
i like my rb50 in my wgt, waiting for another warranty rb50 for my touring.
i send to max chow [email protected]
it took 1 week until i get reply
and seems like it will cost me $80 for warranty
#1623
#1625
#1626
kinda new to teamwave.
what is the latest software? 2.02g or 2.1c?
#1627
#1628
I ran 2.1c on my RB50 for the first time last friday night in 13.5 and took FTQ ran it with the temp cut off turned off and no problems motor was coming off at around 75c hth
#1629
#1630
did anyone compare the latest version of rbs with genius genII or Tekin?
Is the 2.10 sw a big improvement to the previous version?
#1631
Q2. It seems better, if not better it takes some of the guess work out of finding a good working profile, so it sort of simplifies settings with as good a performance.
#1632
I was running aTeam Powers 13.5 and the settings were in the mid ranges I will post the settings I used in a couple of days as not going to be able to check on speedo till later in the week. But our track is a fairly small tight circuit indoors longg but narrow
#1633
We run on a tight twisty track and do not feel the need to run the turbo at all, as it comes in not long before you need to brake for the corner, so it will just generate more heat for not really a faster laptime.
To give you an idea, my nearest competitor is running a Tekin with turbo on the same motor. I am 80/27 on a 416WE and he is on a 78/23 on the same car.
He IS faster down the striaght, but I am the one still winning.. I have used his car and all though its quick, it seems far less drivable than the Team Wave.
Nice though it is to have THE fastest car down the straight, it does not always work out when you check your lap times.
Given all that.... I have tried the turbo, and I would say the Tekin and Team Wave 2.1 firmware are very comparable.
Hope it helps a little bit, always more than welcome to drop me a message if you need a hand
#1634
I am running Team Wave motors and Team Losi, both 13.5 coming off at 60c MAX and the speedo around 30c.
It is good to find out what settings other people are using.
I will post my settings when i have found the sweet spot.
#1635
Hi things are going well this end and im very pleased with the results so far and we are still doing some testing with gear ratio and speedo settings.
1-6 (or 8)
2-6 (or 8)
3-1
4-1
5-8
6-5
7-4
8-1
I only tried it last Tuesday and I cant remember!! LOL
