Old 03-24-2008, 08:00 PM   #1
wstuart's Avatar
Trader Rating: 109 (98%+)
Send a message via AIM to wstuart
Default carpet foam tire question
Ive never raced carpet before but i have a carpet TC and a bunch of GRP foan tires for it (28mm). What diameter should I true the tires to for racing. 0 the new ones have alot more foam that the ones on the car - i just dont know how much to true. Also are there guys at teh track who will true your tires for you. Im thinking aout don Bending corners carpet
wstuart is offline   Reply With Quote
Old 03-24-2008, 10:20 PM   #2
SammyZ's Avatar
Trader Rating: 138 (100%+)
the GRP tires you have come pre-cut to 58mm, alotta guys cut down to 57 but 58mm will be fine as long as your body is safe of sharp points!
SammyZ is offline   Reply With Quote
Old 03-25-2008, 05:00 AM   #3
Trader Rating: 16 (94%+)
This same is true for all sedan/touring 1/10 scale Foam tires. You can run them out of the box, but the most predictable and consistent handling usually starts in the 57-58mm range.
kn7671 is offline   Reply With Quote
foam tire question teabag Rookie Zone 4 02-07-2007 02:32 AM
Foam Tire Question??? NotSoFast Electric On-Road 15 08-13-2006 08:53 PM
Foam Tire Question markallen Nitro On-Road 0 12-27-2005 09:52 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 01:51 PM
Foam tire question- nomaak Electric On-Road 18 12-12-2004 07:19 PM
SEO by vBSEO 3.5.0
