LiPo! LiPo!
LiPo! LiPo!
From some NiMh VS LiPo forum I read,
The Lipo must keep in 40% of its total charge capacity to ensure life expectancy. It could last for very long time and takes many cycles without degrading in a well control environment.
Over Charge or Over Discharge LiPo overheats the Lipo cell, is also dangerous. The Heat damages the cell and shorten its Life Expectancy greatly. Many LiPo reaches it's point which are no longer safe to use. !!It can Really Blow your RC into pieces!! Those Extreme Heats it can produce can even catch metal into fire. check out youtube for lipo.
Lipo cell are fragile, it needs protection in High G Environment. An internal shortage of a damaged cell could cause Heat and destroy your RC car completely!
We are still in the drak age of LiPo. Higher output cell, the more active chemistry, the high risk. Be a Wise Careful person when using LiPo.
team orion carbon edition lipo... Is it any good for racing???
Believe it or not, all batteries are affected by Depth-of-discharge. Mostly this term is talked about in Lead-Acid/Gell batteries but applies to all forms of batteries.
It is expected that just using the battery will result in a decrease in performance in the future. How hard you use the battery will determine how much of a decease. Batteries do not get better with age.
beta bob
I have been running the same two (2 because of time between races) Orion Carbon 3200s for the last 17 months (2 charges per week) and they are great race packs.
do you think i could rely on one carbon edition for a month or two?
well i don't have 30-45 minutes more like 15-20 minutes but that would be enough time to top it off right? does it really take that long to charge one??
interesting stuff
My abd guys after thinking about it i have like 30-45 Minutes on most race weekends but there are weekends were a lot of our racers go to big races and we have like three classes which is about 25 minutes between each of my races.
