Old 07-11-2003, 02:18 PM   #1
Registered User
Default tc3 gearing question
i need to know whats a good pinion for stock racing ?
i want faster take off im using a 28 teeth
SuCioDiFiciL is offline   Reply With Quote
Old 07-11-2003, 02:28 PM   #2
mo's Avatar
If you want your car to accelerate faster, simply go to a smaller pinion gear (less teeth). This will make the car take off faster but you will loose top speed. Try dropping to a 26 tooth pinion.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 07-11-2003, 03:54 PM   #3
Send a message via AIM to DraKhen99
I got decent performance out of a Trinity P2k Pro with a 25 tooth pinion gear. This is the gear that came with my car, or that I picked up for it... I can't remember, it's been too long!
Do a search on Google for "r/c gearing", you'll come up with all sorts of helpers on this... gearing calculators, etc.
DraKhen99 is offline   Reply With Quote
Old 07-11-2003, 05:39 PM   #4
it all depends what motor you're using and what track size you race on. but as mo said for more acceleration, try a smaller pinion. by doing this you will lose top speed, though.
Trippin Freddy is offline   Reply With Quote
Old 08-04-2003, 12:19 PM   #5
I get good results with my P2k and a 25t pinion and I race on a pretty tight track. Monster stock work well with a 21t. Reedy MVP would probably do good with a 23 or 24t. But I haven't tried my MVP yet. A P2k2 would probably do good about the same as the MVP, but my p2k2 is broken, one of the magnets in the can broke . I'm using a TC3 with the stock 72 spur.
racerdx6 is offline   Reply With Quote
XXX-S Gearing Question TeamPink91 Electric On-Road 7 05-15-2010 08:55 PM
Gearing Question jeffbhhs Electric On-Road 3 06-12-2008 04:26 PM
AE 12L gearing question. MrZero Georgia Racing 4 11-06-2007 09:42 AM
Gearing question Sal Amato Electric On-Road 1 09-09-2006 12:01 PM
T3 Gearing Question DraKhen99 Electric Off-Road 2 07-18-2003 07:36 AM
SEO by vBSEO 3.5.0
