Old 03-10-2008, 03:50 AM   #1
Default Gear information module and pressure angle
Want to know for out 64 pitch and 48 pitch gear, what is the module and the pressure angle? thanks
ioxqq is offline   Reply With Quote
Old 03-10-2008, 04:06 AM   #2
Trader Rating: 22 (100%+)
Please explain?
Dont understand the question.
Is your car slow..Xray it!.......FK05, M18, M18t
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 03-10-2008, 06:43 AM   #3
Trader Rating: 14 (100%+)
Your module is the diametral pitch divided by the number of teeth
diametral pitch is defined as the number of teeth per one inch of the pitch circle diameter
For the pressure angle, its the angle between the tooth profile and a radial line at its pitch point.
Some pretty simple plug and chug for your module. The pressure angle would be a little harder to figure out but they are usually a set standard for pressure angles.
I dont have any gears in front of me to calculate the stuff out. I also have bigger engineering fires to put out
Why do you need this information anyway?
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 03-10-2008, 07:09 AM   #4
fpart's Avatar
Trader Rating: 37 (100%+)
Send a message via Skype™ to fpart
I was wondeirng that also. Must be making his own gears!
teamYokomo.com teamTrinity.com Sweepracingusa.com
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 03-10-2008, 08:42 AM   #5
Thank you for the information. Yes, I'm trying to make my own gear. The problem is I don't have a machine to measure the teeth. If someone knows, please let me know. thanks
back pressure effect on performance, mileage, - max power back pressure adjustment tomkelley Nitro On-Road 4 07-31-2008 04:12 AM
NT1 720 MTX4 Gear module? ioxqq Nitro On-Road 1 03-14-2008 07:58 AM
KO helios with spektrum pro module, pro reciever ,multi angle wheel vintagetamiya R/C Items: For Sale/Trade 9 10-12-2007 08:54 PM
Futaba 3PK radio Gear - FM Module / Rx's / XTals SoCalTazer R/C Items: For Sale/Trade 3 11-27-2006 07:30 AM
Spektrum Telemetry Module: Real-time information for real racers. Artificial-I Nitro On-Road 23 03-01-2006 08:38 AM
SEO by vBSEO 3.5.0
