GEARING HIGH OR LOW
GEARING HIGH OR LOW
Hi can someone tell me if I was gearing a kd 19t at 6.2 final drrivve to make it faster would I have tto gear at 6.0 ffinal drrive or 6.4 final drive. I am running rubbers on a big track
Bud the lower numerical value for gear ratio's will give you more speed at sacrifice of a bit of accelleration/punch. The higher numerical value for gear ratios will give you slower speeds and better/faster accelleration.
With roll out its the other way around ie:
lower numerical roll out value is slower speed and better/faster accelleration
higher numerical roll out value is more speed and a little less accelleration/punch
Hope this is clear.
Hope this is clear.
Hope this is clear.
Hope this is clear.
thanks that helps so am I at the right final drive for a kd19 turn?
cant speak for gear ratio but we run them at around 28mm - 32mm rolll out depending on the track.
