HELP ON BATTERY DISCHARGER
NEED HELP IN CHOOSING A BATTERY DISCHARGER,,DOES ANYBODY STILL USING THE OLD STYLE BULB DISCHARGER WITH CUT OF BOX ON IT?
Side by side NiMh packs are easier the discharge by rack dischargers. i.e. Tekiin doctor. It discharges @ 2amps, and cut off @ .09-1v. Light bulb discharger are still used but by experience they cut off too low if forgotten them. Ruin a side by side pack 4600mah with only 5 cycles. it will kill the weakess cell. Even though NiMh don;t carry a memory.
Lipo you should discharge @ 3V per cell. or 6v 2C lipos, 7.4v 2C @ 6V cut off. Lipo's probably discharge at manufactures specs. Most lipo'e have a balancing port. Balancing every 3rd charge is recommended. Good lipo chargers Have Charge, Discharge & storage function.
Lipo's if racing, there is only lipo's with hard case that are legal. there is only 9 lipo that are legal with ROAR. ROAR webSight will tell you which ones are legal.
I have a question reguarding an Integy zero-thirty discharger. I just picked one up used. Is there a minimum amp rate for it to work properly? Do I need a 30 amp or giher power supply to run it? I apologize ahead of time if it seems like a dumb question but this is the first discharger I have had other than a novak smart tray. Thanks.
