Setup for tc3
Registered User
This really should be in the TC3 thread, you don't need a seperate thread.
Registered User
No need to flip out now, I think all fatdoggy was trying to say is that you should ask your question in the tc3 thread. I don't think he was trying to tell you to just look through all the posts in the tc3 thread. You would probably get faster answers asking your question in the tc3 forum, instead of creating a seperate thread. Just my .02
Well that setup you have there is a good one for rubber tires, but quite a bit off for foam.
First off, try running Plaid (or Purple/Orange as Jaco calls them) in the front, it'll make the car easier to drive.
Try 70 wt oil front, 60 rear
yellow front springs/ copper rear
outer holes on arms
outer hole front shock tower for shock, middle rear
Fr and Rr camber links upper inner
4 degree caster blocks
-2 degree camber all around
F-0 block in front
R-0+2 block in back (0 kick, 2 degrees toe)
4 mm ride height
Droop 6 front, 4 rear
Dual Diffs, Try a spool (locked diff) if it's a wide-open layout.
Try battery in back first, too.
outer holes on arms
F-0 block in front
4 mm ride height
Registered User
racerdx6 - Thanks, that's exactly what I ment.
Originally posted by ajg
racerdx6
I did post in the tc3 thread. I wasn't flipping out. And in my last tc3 question tread people actually answered my questions.
racerdx6
Registered User
Registered User
[ I'm 15 and have no job so I can't buy anything too expensive, [/B]
Originally posted by racenut123
This statement answers everything guys. For someone who wants help you sure going about it the wrong way. Also if someone makes a suggestion and you say this is what the other guys at your track are running, why dont you ask them for help. Could it be your a punk and they don't want to help you either?
fatdoggy
You obviosly don't know the answer, so why don't you go wine to someone else.
fatdoggy
Registered User
