The Best Rims
#17
johnA, it is the tires, when pete tried them he found they didn't sit on the rim very well either.
#19
I like the Yok wheels, very durable.
#20
I use the yellow Yok rims, they look trick
#21
The speedmind rims have never failed on my car, and they look awesome!
#25
Originally posted by JDM_DOHC_SiR
Here you go..
Hot Bodies Rims
-Dave
Here you go..
Hot Bodies Rims
-Dave
#27
Originally posted by Herminator
now thats just not fair, trying to get an advantage whilst driving by distracting other drivers with those things next you'll be painting swirly patterns on them to hypnotise drivers too
-Dave
#29
The Best Rims
Tamiya makes the Best RIMS!!!
they are the reinforced rims by Tamiya,
I've been using them since I started the Hobby, just a bit expensive but it will pay for it self because you can use it several times!!!! the only draw back is its color black and the dull finish because of the carbon, graphite and nylon components!!! I've took, BIG hits, direct, indirect, cartwheels and so on, you could not wreck these wheels!!!! they are not brittle, does not bend, break and wont loose balance and will stay true
Again they are the TAMIYA Refinforced Rims
ITEM 53335 (OP335) 5 Spoke
ITEM 53336 (OP336) Mesh
Second are the ones from Yoke, the rims that are specified for the MR4-GT!! they are sturdy and would outlastthe tries, but also loose its balance it hit very hard (not unlike the Tamiya Renforced)
#30
Re: The Best Rims
