Best Soldering Iron for Batteries?
Hi guys,
I am in the market for a good soldering iron to solder my batteries. I found a 40 watt weller soldering iron at home depot and don't know if this will be good for assembling battery packs. Does anyone know what a good soldering iron would be? Preferably within a low budget
thanks
thanks
With all the fragile cells on the market, I woulndt use less than a 80 watt
Price on the 80w Weller is less than $35.00.
Hakko 936 is the only way to go
I also use a Weller 40 watt and there's ample heat to do batteries easily (including taking them apart). What is the deal with the tip though? I've never left mine on for longer than a few minutes and it still pitted very quickly.
I have the Hakko 936 for doing all my soldering tasks, except assembling packs. For that I use the weller 80 watt behemoth. Quick and painless. The faster you make the joint with these new cells the better. Let the iron recover between joints and you won't overheat a pack while assembling.
The 40w and 80w wellers will burn out the tips if you use them all the time, but they work great for occasional big jobs like doing packs.
The Hakko 936 rocks for using all day long at the track etc... and it's not bad for doing packs with the big 908 iron and tip, but nothing compares to that massive 80w weller tip.
I have the hakko too, but stays at home.
At races I use this:
http://www.goot.co.jp/ENGLISH/catalo.../PX201_401.htm
Variable power iron, but very compact and powerful. It gets to max temp in 20sec. If you use the 5mm tip, battery bars go on/off quickly without heating the surroundings too much.
You can by direct at www.hakkousa.com or most online shops (stormer, amain, tower) have them. I got mine from stormer hobbies.
Weller WLC200
Just got this from a stained glass supply company. 80w iron with 3/8 chisel tip that just solders like a demon for batteries. Perfect to keep from boiling up those top packs.
Stained glass hobbyists apparently pay less than us. $100 for this item in hobby shops and $80 in stained glass supply houses. $20 savings not much but 20% in my pocket is preferable to me.
This iron replaces my string of maybe 6 $10 irons in 4 years.
