Brushless run times
Brushless run times
Hi Gang
I have been outa this for a while but used to run a F1 and a what they are calling a vintage RC10 . What would the approx run time be on a brushless setup and how much of a bearing would battery choice have on the ruun times?
I am running a 4tec right now with a 10 turn double on a cyclone speed control and 2400 battery sticks and am only getting about 2.5 min run time. Any suggestions without spending a wad on batteries of how to get a longer run time?
I know this isisnt a brushless system now but why upgrade is another thing im looking at
Jeff
Jeff
WHAT IS YOUR ROOL OUT...PINION,SPUR,& TIRE SIZE..?
MOTOR TEMP AFTER A RUN?
I wanna say my spur gear is 48 and the pinion gear is 24 tre size im not sure of and motor is semi warm as far as exact temp goes im not sure.
Sorry so vauge but im still fairly new hehehe
Jeff
Jeff
your problems are----
1. TOOOOO tall on the pinion, it comes geared at 24 (pinion) /81 (spur) and this is for it's wimpy 20 turn motor
2. To much drivetrain drag, this is one thing on the car that will be hard to fix because the belts are absolutely way too stiff.
3. Your motor is worn out and needs rebuilt.
4. Your batteries aren't getting fully charged.
If you go out and get a brushless system you will only fix one of these problems......
This is possiable I have a peak charger coming this week
motor is new and has less than 5 runs on it was broken in witht eh water like directions state
I dont think this is it because i got longer run times with a 15 turn
What gearing would you suggest?
Jef
Jef
Ok I will try the 18 to 20 pinion gear and let ya all know. Thanks for you patients with this old newbie
Jeff
Jeff
