Hard case lipo pack under $35.00 bucks!?!? >
Old 02-27-2008, 06:49 PM
  #31
daveaustin5's Avatar
Whilst it wouldn't be easy to tape into a TC, it'd probably still stay down if you squeezed the tape between the output and the other cable.
I might get one just to try it. Shame it has a crap connector on it and not 4mm poles. I guess it'll be marketed as a replacement to a traditional stick pack.
daveaustin5 is offline
Old 02-27-2008, 07:06 PM
  #32
RussB's Avatar
just because it looks like an orion doesn't mean it is.
the chinese make knock off's of mercedes benz, doesn't mean they're the same thing.
RussB is offline
Old 02-27-2008, 07:22 PM
  #33
HarshGuy's Avatar
Except it's pronounced meLcedes bRenz
HarshGuy is offline
Old 02-27-2008, 08:50 PM
  #34
Skruger's Avatar
Trader Rating: 16 (100%+)
Wink MiNI Ready
Originally Posted by -KilleR-
dang!! Why do they need to comes with those bumps. Can't use them in minis.
MiNI Ready
My conversion for the Mini Cooper.
BTW I think these are being sold cheap because they would fail ROAR DROP testing.
However the Core 3250 Passed Roar testing
Attached Thumbnails Hard case lipo pack under .00 bucks!?!?-0127081927a.jpg   Hard case lipo pack under .00 bucks!?!?-0127081927.jpg
Last edited by Skruger; 03-01-2008 at 10:24 AM. Reason: Core 3250 Passed Roar testing
Skruger is offline
Old 02-27-2008, 09:28 PM
  #35
SammyZ's Avatar
Trader Rating: 138 (100%+)
how did you get the wires to come out the side like that?
SammyZ is offline
Old 02-27-2008, 10:12 PM
  #36
Skruger's Avatar
Wink
The casing is so poorly glued that all you got to do is split it like cracking Crab legs .there is no tape holding the battery's to the casing
remove the BATTERY
Dremel as needed at the ends for the wires and then
INSTALL the BATTERYS and glue/shrinkwrap the case.
I like to use shrinkwrap for stick packs because it makes a tighter fit in the MiNi also note the WEIGHTS are held in by the shrinkwrap and the battery gets installed UPSIDE DOWN for lower CG
This is BTW TCS Legal...(orginal label is under the weights)
BTW: this will Void the warranty
Skruger is offline
Old 02-27-2008, 10:23 PM
  #37
glassdoctor's Avatar
I did a similar mod to my Core-RC 3250 packs... put the wires in the same spot as the Core 5000 pack, and I got rid of the balance connector. I cut the red and black balance wires and kept the blue wire... and have it coming out with the main leads. It's a nice clean look.
But yes it does void the warranty, whatever that is? Personally I have never expected to hold any company to a warranty for batteries after they have been used. I guess I would do something with a DOA pack...
glassdoctor is offline
Old 02-27-2008, 10:28 PM
  #38
Goingfast's Avatar
Trader Rating: 29 (100%+)
What is your opinion , 3250 core lipo? Do you think the Orion 3200 lipo are better than the 3250 core?
Goingfast is offline
Old 02-27-2008, 10:37 PM
  #39
Though I'm chinese by race.... But I still try to steer clear from 'Made in China' product...
Don't know when will those blow up??
Ben.C is offline
Old 02-27-2008, 10:40 PM
  #40
Skruger's Avatar
I think these are the Same OEM as the Core 3250 and are being dumped cheap because of the Failed Roar Drop test on the hard case shattering
Skruger is offline
Old 02-27-2008, 11:27 PM
  #41
odd.. this seems to be the first yeahracing product that doesn't seem to be up to snuff with their other good quality products, given that the seams are glued poorly.
Sabin is offline
Old 02-27-2008, 11:35 PM
  #42
I have no idea really but I expect the Core 3250 to be pretty good. I just got them myself, and I don't own an Orion 3200 although I can get my hands on one. I hope to compare them and others soon...
Old 02-28-2008, 09:12 AM
  #43
ROCKHARD 10's Avatar
This is why I Love the (INTERNET) FOLKS.
ROCKHARD 10 is offline
Old 02-28-2008, 09:21 AM
  #44
What is the "this" referring to?
Old 02-28-2008, 09:35 AM
  #45
Isn't it better to have the case taped to the cells rather than the whole thing shrink-wrapped? That way when the cell puffs, the case expands rather than building pressure and potentially exploding.
Jeckler is offline
