Revive tired 33k GPs
If you can't get in more than 3000mah to your 33k GPs chances
are they're tired. Steps to follow to bring back to almost new condition. step 1: fully discharge to .85v/cell step 2: tray them until lights go out step 3: short the cells individually (not using a tray cuz some of them have resistors and diodes that have auto cut off.) for 30 min. to an hour ( batts will just get warm and not hot) and let batts cool step 4: As batts are cool individually zapp the cells several times per cell using a hi volt zapper (200v+) step 5: Charge battery (as a pack) using you normal procedure then discharge at pref. at 20-30amps and your batts are close to new. (it may false peak on 1st charge) note: If you dont zapp them ave. volts will not improve. TRY AT YOUR OWN RISK! |
have you tried this
anyone build there own zapper before? |
Umm....bad charger? Some chargers will not charge about a certain MAH......something to consider. What flavor of charger are you using??
zapp at 200V+!!:eek: :eek:
Who makes such a zapper....I am interested!:D |
can you make your own zapper?
home made zapper
Tried making one myself. downloaded diagram from internet.
when i trigger it with a tester on it reaches about 200v. the volts depend on capacitor you use. u can dowload diagram from this site : http://www.electronichobbyist.net/pr...cad_zapper.htm |
Originally posted by dtm zapp at 200V+!!:eek: :eek: Who makes such a zapper....I am interested!:D -Dave:sneaky: |
How many volts does the XIPP Xapper put out?
whats the diffrence between building one and buying one
whats the difference in building your own car or buying one built for ya? $$$$$$$$$$$$$$
xxip 3000dcx was 90 volts xxip 3300dcx i think is a little over 100 you need a comercial grade zapper the sky is the limit! :spidey: |
What other zappers are there on the market?
batman is this proven to work. i havent tried my batteries yet to see if they lost any run time but is this proven to work
i just checked my gp's and there not getting woarse there way better then 3300's
i fully discharged it (not with a tray) charged it with my millenium pro and it charged 3654mah into with one charge at 5 amps anyone get this out of there gp's |
The older and newer (as of February) GP3300s like to be discharged all the way down, put on an Integy or trinity discharge tray, and dead shorted.
I just bring mine down on 15 light bulbs, then one light bulb to finish it off. The I take a piece of wire and solder it to each of the battery bars to deadshort the pack. This drops your IR and adds keeps the voltage, at the expense of runtime...Good for stock racing of 4 minute races. Charge at as high as 7 amps, with your pack on a heating pad. Keep the pack on the heat pad until you put the pack in your car. This adds voltage to the pack, with no noticable loss in runtine. No change in IR from what ive seen. |
I have 3300 GPs that go to 3400-3600 so I think it's fairly normal if you get a nice pack.
-Sushi Boy |
