Hudy 1/10th Scale Arbor?
Which one would I need for doing 1/10th scale Spec tires? I found two part numbers, http://www.hudy.net/xhudy/products/p...&kategoria=150 and http://www.hudy.net/xhudy/products/p...&kategoria=150. Just curious which one I would need. Thanks.
Anyone?
Arbor WA-CB 1/10th. Will work both Serpent, Mugen, HPI, Tamiya. can still be used for Pancars.
Originally Posted by BigRed
(Post 4205193)
Can you be more specific about what kind of car you'll be running? "1/10 scale spec tires" could refer to touring car tires, or pan car tires... If you are referring to pan car tires, then the first of the arbors you listed would be the one you want. |
Sorry, the Spec foam tires for 1/10th pan car.
For 1/10 pan cars, the first of the two links in your original post would be the arbor you need.
