Old 02-25-2008, 11:48 AM   #1
nashrcracer's Avatar
R/C Tech Charter Subscriber
Default Will the FAA ban LIPO laptop batteries?
Mike Elgan: Will the FAA ban laptop batteries?
Mike Elgan
February 22, 2008 (Computerworld) Laptops are the best thing that ever happened to airline travel. They enable you to catch up on your work, play games or watch a movie while you are traveling.
Better still, many airlines are now installing costly equipment that enables you to access the Internet during flights. Most of these systems use your laptop's built-in Wi-Fi to connect.
Unfortunately, this laptops-in-the-sky nirvana probably won't last. The problem: Laptop batteries can explode catastrophically. It's happened before, and it will happen again. It's only a matter of time before it happens in-flight.
The FAA forbids you to use your iPod during takeoff do you think it won't ban laptop batteries?
What's so bad about laptop fires?
Laptop batteries are typically plastic and metal containers that contain somewhere between six and nine individual lithium-ion cells, which look a little like AA batteries. If any of these gets too hot around 350 degrees for legitimate, noncounterfeit batteries they can leak flammable liquid, then explode, causing a chain reaction through the rest of the cells (a process called thermal runaway). The temperature increases and quickly melts a hole in the laptop. As additional cells explode, flaming, poisonous liquid can be thrown several feet in any direction. These explosions and flames are accompanied by acrid, toxic smoke.
The reaction on a crowded airplane to multiple explosions, flames and toxic smoke could easily be panic. People would get up out of their seats and move down the aisles, blocking the path of flight attendants trying to extinguish the flames with on-board extinguishers. The rush of passengers to the front or back of the plane could affect the pilots' weight-and-balance calculations. And the FAA itself admits that airline crews are ill-prepared to handle battery fires in-flight.
Another risk is that terrorists could board a plane with a large number of laptop batteries, both in laptops and in laptop bags as "spares." During flight, they could combine all laptop batteries into a single unit, then heat them up to create explosions, fire, panic and, possibly, damage to the airplane.
Here's what happens when laptops explode <http://blogs.computerworld.com/exploding_laptop_cinema>.
What the ban would look like
New rules came into effect Jan. 1 that ban spare laptop batteries in checked luggage. Batteries actually installed inside devices are allowed, and most spare batteries in your carry-on are fine, too. But carry-on batteries are now governed by a complicated new set of rules.
You can carry batteries with 8 grams of lithium or less in your carry-on luggage, but they must be carried in plastic bags. Cell phone, PDA and other gadget batteries, plus most laptop batteries, contain less than 8 grams of lithium.
You're now limited to a maximum of two batteries with between 8 and 25 grams of lithium in them. The most common batteries in this category are "extended life" laptop batteries, but also batteries used in larger devices like projectors. If you carry on three such batteries, security will take one of them away. None of these rules would prevent the kinds of standard laptop battery fires I linked to above, especially since batteries inside laptops are still allowed.
Laptop fires are more likely with counterfeit or faulty batteries. The airlines will never be able to check the legitimacy or safety of batteries, so any ban would apply to all batteries regardless of quality.
It seems to me that batteries installed in laptops pose the greatest risk. If you close your running laptop, but it doesn't go into sleep mode as it's supposed to, it's likely to get very hot inside your insulated laptop bag.
Another risk is multiple batteries stowed together, because a chain-reaction explosion gets hotter, more dangerous and more difficult to extinguish as additional cells and additional batteries ignite.
When or if a laptop battery ever catches fire in-flight, we can expect new rules. I think the most likely future FAA rule is that laptop batteries will not be allowed inside laptops, but carried only in plastic bags and never stored with other batteries. Although this is far less catastrophic than total battery bans on all flights, it would ruin the Wi-Fi laptop nirvana I described.
What's the long-term solution?
The problem with laptop batteries is lithium, which is highly reactive. In order to break through current limitations with weight and battery life, the industry is already working on next-generation batteries that don't contain lithium. Unfortunately, some of these alternative power sources also contain flammable or toxic materials.
The Pentagon is currently organizing a DARPA Challenge-like contest called the Wearable Power Prize < http://www.dod.mil/ddre/prize/> for next-generation batteries that are very light, very powerful and very long-lasting. The military is specifying a maximum weight of 8.8 pounds, but the batteries must produce at least 20 watts for four days. Some of these likely solutions could use rocket fuel inside the batteries! Others may involve safer alternatives to lithium (or rocket-fuel) batteries. Companies and universities around the world are also working on better batteries.
Until someone invents a better battery, all frequent fliers can do is wait and hope that my prediction of in-flight laptop explosions, and a subsequent FAA crackdown, never comes to pass.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Hyperion Lipo Charger and (2) 3s Lipo Batteries RcOneNitro R/C Items: Wanted to Buy 3 07-27-2008 11:31 AM
compaq laptop and dell non working laptop for sale songofthesword Other Items: For Sale/Trade or Wanted to Buy 1 03-22-2007 06:10 AM
Dell Inspiron 6000 Laptop Computer----$650, Latitude C600 Model PP01L Laptop ----$350 kallam Nitro On-Road 6 10-25-2006 03:42 PM
2 Savage Trucks for a Nice Laptop. Or 1 for a laptop. Check Them Out! (RTR) Maxx-Power03 R/C Items: For Sale/Trade 5 10-26-2005 05:37 PM
2 Savage Trucks for a Nice Laptop. Or 1 for a laptop. Check Them Out! (RTR) Maxx-Power03 Other Items: For Sale/Trade or Wanted to Buy 1 09-12-2005 04:24 PM
SEO by vBSEO 3.5.0
