Old 02-26-2008, 06:33 AM   #16
Pita's Avatar
Originally Posted by RFrancis View Post
Just another thing, here in Portugal, I don’t know any grape soda…
We do have orange, pineapple, peach and other fruits sodas, but grape… I don’t know…
Will Coke or 7up do the same effect?
In Carrefour supermarket, you can find POSTOBON, a grape soda, made in colombia.
http://picasaweb.google.es/joselillo.ruiz "my pics"
Pita is offline   Reply With Quote
Old 02-26-2008, 07:13 AM   #17
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Washed sufaces:
When you wash the surface then layout your track you shouldn't have any problems with what solution you spray. Whether it is grape soda, grape snowcone syrup, pancake syrup and water, or sugar water. They all give you good results as long as you don't over spray. Grape is the preferance by most because it has more sugar. Others have tried root beer and orange soda also.
Vaccuumed/Blown surfaces:
When you vacuum or blow off a surface it is harder to get the perfect results every time. That's why it is better to wash a surface but harder work. I see noone mentioned the quick fix for dusty sections of a track. When you have a track that hasn't been washed you can spray a mist of WD40. Yes the same WD40 used as a lubricant. In sections where the tracks is dusty, spray abit of WD40 to help settle the dust deeper into the asphalt. It is easier than trying to remove it without washing. Then you can spray your traction mixture on the rest of the track.
What ever method you use make sure you allow enough drying time before cars run on the track. Racers tend to put their cars on the track before it dries and that makes it worse for everyone. It removes the spray from the ground and is picked up by the tires.
Good luck and I hope this helps you with your goal.
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
Thanks to the SoCal guys that help me & "Tha Man" Paul Lemieux
Racing TC Class where allowed with what I have.
F. Mendoza is offline   Reply With Quote
Old 03-27-2008, 11:48 AM   #18
Send a message via ICQ to arstron Send a message via AIM to arstron
My local club is going to be preparing a oval with a smooth finished concrete surface like this, what type of tires would work on somthing like this?
arstron is offline   Reply With Quote
Traction alternatives to VHT or Soda/Sugar Water or8ital Electric On-Road 21 08-30-2008 05:24 PM
What carpet to get for outdoor offroad track? tips for making a track? layouts? xtremelimits285 Electric Off-Road 2 06-17-2007 07:38 PM
Asphalt Traction - Sugar to Water Ratio A. Rhodes Electric On-Road 27 03-17-2007 02:43 AM
Looking for Track Building Tips beerbarron Electric On-Road 6 12-06-2005 10:43 AM
Water Sanding water based paint? Rowdy Racer Painting, Designs, Graphics and Photography 5 02-02-2004 07:07 PM
SEO by vBSEO 3.5.0
