Whats the Equilivent?????????
Since takeoffs and RP's are no longer making tires i'm looking at sorex. What sorex tire is the same or very close to the cs-27???? I can't fine a chart for them at all. This is what i was refering to:
SITE: (http://www.aps-racing.net/index.html?lmd=39478.717187)
SPEEDMIND-SOREX Premounted Rubber Slick Tires, 4 pcs
SOREX Japan and SPEEDMIND have teamed up together to introduce pre-mounted SOREX tires for both indoor and outdoor racing.
Factory pre-mounted SOREX tires will be marketed under SPEEDMIND in N. America, sold in convenient pack of 4.
HIGH QUALITY/STANDARD
SPEEDMIND’s exclusive & renowned “K-28 Impact Master” German composite aero-dish white wheels….strong and durable wheels
SPEEDMIND racing profile inserts
Convenient factory pre-mounted pack of 4
Available in popular SOREX compounds : 24R, 28R, 32R, 36R & 40R
GT40424W : Sorex 24R
GT40428W : Sorex 28R
GT40432W : Sorex 32R
GT40436W : Sorex 36R
GT40440W : Sorex 40R
The CS tires are strange. Even though you would think the CS27 is too soft for asphalt its the best CS series compound for asphalt. It also is very good on carpet. No other tire has such a broad operational range.
Sorex tires are different.
For running on asphalt the Sorex 36R is best. This tire is a lot softer than the number would lead you to think and works well from cool to blazing hot weather.
For running on carpet the Sorex 28R is best. This tire is awesome on carpet and has a lot of grip.
I found these values on another thread. I dont know if these are right or not.
Temperature ranges:
Sorex as follows:
28R - 68-84
32R - 81-96
36R - 96-151
40R - 120-170
Take OFF CS:
CS22 - 32-86
CS27 - 50-122
CS32 - 68-140
CS37 - 104-158
Temperature ranges:
Sorex as follows:
28R - 68-84
32R - 81-96
36R - 96-151
40R - 120-170
Take OFF CS:
CS22 - 32-86
CS27 - 50-122
CS32 - 68-140
CS37 - 104-158
RR - those temperature ranges are pretty close, but it all depends on track surface, preparation, car setup, and inserts.
36's will work at lower temperatures than stated, but warmers are a must have.
If its COLD you can run Sorex 28R or 32R outdoors but if the track is over 80*F the 36R will last longer and be just as fast.
I must say Sorex are the best tires in the industry. Hands down...!
The 40R are so good and last quite well under the blazing sun in the tropics!
