pro3
#1381
HPI 23RS stock motor
Hey Guys;
Can you change the Springs and Brushes on these Motors (23T)? If so then they might be OK.
Out here in CA, USA. 19T is called the Spec class and 27T is still considered the Stock class.
#1384
TAMIYA Type-R
that is a fixed endell, you can't cut the com. get the Type-S or the Type-RR
#1386
Yep
you can't cut it!! but its a powerful motor compared to typeT
get the S or RR
get the S or RR
#1387
For those inquiring about a two speed transmission for their Pro3, TC3, or just about any car...
one is now available.. see listing on Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3104200883
#1388
Electric 2spd transmission
I don't see the advantage of THAT one. It looks all metal (heavy) and the 2nd gear ratio is only 1:1. The gears look awful thin too. Too heavy for a Stock Motored race car and too fragile for a Mod Motor.
Would probably be great in something like the Tamiya Pantero kit or a Clodbuster.
#1389
Amazing how a little water can change things
Guys;
I didn't realize immediately that you are overseas from me. Funny how things will be different and when we answer posts it's so easy to forget that everyone is not reading out of the same book.
#1390
3 & 4 degree Caster blocks
Originally posted by sosidge
By my calculations, you need the 1mm spacer on the block to get the standard position.
#1391
I'm not sure what the end effect would be, but with the 2 degrees you get from the plate the suspension arms will swing at a slightly different angle. I think that may have the effect of adding kick-up as the suspension compresses, not sure though.
#1392
• 2° kickup will work best in most conditions, especially bumpy conditions.
• 0° kickup will have a more aggressive steering feeling but will not absorb bumps as well as 2°.
#1393
Kick-up
rc-zombies;
Thanks,
I think that I'm going to try the 3 deg "C" blocks along with the Kick-up at 2 degs. That will give me 1 deg less that what I'm running now and hopefully slightly more HS steering.
Thanks,
#1394
Werent you asking the difference between using the 6 degree blocks, as opposed to the 4 degree blocks, and then using 2 degrees that block that holds a arm pins in. If not I am asking it, cuz it would be interesting to know the real answer.
#1395
6 Caster + 0 Kick-up = 6 total
OR
4 Caster + 2 Kick-up = 6 total
What would I notice in the handling if anything between the two set-ups.
