Like Tree13Likes
pro3
Old 10-06-2003, 07:24 AM
  #1951
newracer's Avatar
With calvin's help, I now have a NEW and IMPROVED setup sheet. It accounts for graphite shock towers, sway bars, different chassis, all the different castor blocks, and will calculate final drive.
anybody who wants it e-mail me
popsracer I already sent it to you.
newracer is offline
Old 10-06-2003, 07:47 AM
  #1952
This, by the way, is a nice piece of work. Newracer has done a superb job.
calvin is offline
Old 10-06-2003, 09:28 AM
  #1953
church's Avatar
Default clicking sound!!!need help!!
hi! guys, i need help coz when i gun my pro3 theres like a clicking sound, but when you lift the car and then gun it you dont hear it,only when you run the car...what could the problem be??????please help!!!
(how do you guys hold the battery down???coz mine even with the brace, it slides from left to right????)
church is offline
Old 10-06-2003, 09:37 AM
  #1954
newracer's Avatar
the clicking sound is one of your belts slipping, probably the rear since the front is almost always too tight anyways
to prevent the batteries from moving you need some small pieces of foam on both sides of the chassis
newracer is offline
Old 10-06-2003, 09:39 AM
  #1955
Check your spur and pinion gear very carefully for a small obstruction in the teeth. This will sometimes cause the clicking sound you seem to be having.
Also put a piece of foam underneath the battery bar as well as the sides as suggested by newracer
calvin is offline
Old 10-06-2003, 09:40 AM
  #1956
church's Avatar
Default clicking??
so, does that mean i have to replace my belt??(the long belt or the shorter one)
church is offline
Old 10-06-2003, 09:43 AM
  #1957
No, the rear belt tension is adjustable by rotating the bearing supports.
calvin is offline
Old 10-06-2003, 09:47 AM
  #1958
popsracer's Avatar
Default Strange "clicking" sound (Aliens?)
church;
My money is on the REAR Belt being too loose. There is a really fine line between being just right and too loose. Just adust the Belt tensioner 1 notch tighter and it should be alright.
For the Battery Packs, use the little pieces of Foam on the sides (as 'newracer' suggested). You can also put a thicker piece under the Battery Strap to help keep them in place.
popsracer is offline
Old 10-06-2003, 09:50 AM
  #1959
popsracer's Avatar
Default church;
How does the Car drive with all of that Toe-out in the Front. I would think that you would lose alot of Exit steering that way?
newracer;
Thank you, it is great.
Old 10-06-2003, 09:56 AM
  #1960
newracer's Avatar
here is a detail of the foam for the battery
newracer is offline
Old 10-06-2003, 10:24 AM
  #1961
church's Avatar
guys!!check this out!! this is my suspect, i think i have to replace this belt!!!(compare the belt teeth)
church is offline
  #1962
church's Avatar
new belt...
church is offline
Old 10-06-2003, 10:34 AM
  #1963
popsracer's Avatar
Default new belt...
church;
Looks like your Belt has been slipping for some time. Best to replace it. Get the Low Friction Belt(s) while your at it.
Make sure the Pulley teeth are not packed with crud too. This can cause skipping of the belt. Use a pointed object to clean in between the Pulley teeth.
Old 10-06-2003, 10:35 AM
  #1964
church's Avatar
thanks everyone!!!ill keep you all up to date!!!
church is offline
Old 10-06-2003, 09:13 PM
  #1965
church's Avatar
guess what!!!!
its still there!!!! i just installed a new belt, cleaned the pulleys, and still theres a clicking sound!!!!what do i check next?
church is offline
