Keyence Zero extreme ecs
Anyone having problems with the brakes not working on this speedo? Any help curing this problem will be appreciated.
I've got the Zero V Extreme, and I haven't had a single problem with it in the 4 months I've had it. Have you tried reloading the profile?
Rob
Rob
I don't know, I have 2 keyence zero's and both dont have brakes. I tried using different profiles but still the same thing. I even used 2 different radios and still the same. Used both a M8 and a 3pk.
I love mine. I've blown up 2 GT7's since November, but haven't had the slightest "hiccup" from the Keyence. The Keyence's default profile (# 4 or 5, IIRC) seems to have more punch than the "aggressive stock" profile of the GT7, but I like it that way.
As for the "no brakes" thing. Off the top of my head, I think you have to do a "setup" routine with this ESC - I know that on my GT7, I didn't have brakes until I completed the setup properly. You might go back through the manual on the Keyence and see if you missed something.
Rob
Rob
My only complaint with them is that the Zero V Extreme is expensive - a full $50 more than my previous GT7, but it has performed well beyond my expectations.
Rob
Rob
That's not bad - I paid $199 at the LHS.
I try to buy what I can at the LHS to help keep local business going, but sheesh - had I known I could have gotten it THAT cheap, I'd have ordered it online.
Rob
Rob
Bought mine from Steve W last week. Works great. As for no brakes.... are your EPA on your radio set to 100 and not higher? Anything higher and the ESC may not beable to read it properly. This goes the same for throttle. Just make sure your throttle and brake EPA (end point adjustment) are set to 100 or lower.
Anyways, I like mine. Works great. It's nice to beable to store 4 of my own profiles. Like I said... I just got mine... so I'm still learning everything that it does. Can't go wrong with it! Now I just need one for my 1/12th!!
i have 2 for over a yr or so.they nvr let mi down so far.
best i have tried so far...
