Speedmerchant Formula Pro10 >
Old 09-10-2008, 07:07 AM
  #91
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
My Beavis addition Pro-10 should be arriving shortly!!! Got a paint a body now!!!!
Mr. McGoo is offline
  #92
timmay70's Avatar
Thanks OD. I always mis-spell that, and when it gets pointed out want to punish myself for not having a V8...
That was pretty much the vegas set-up aside from glued fronts not much changed.
I can say the sport performed wonderfully, and is also a top level competitor. I know that I didn't really test the full capability of the sport chassis. I did have to add 1/2oz of lead to hit weight after some dieting...
I got to the track too late last night to actually set-up a pit. I am hoping for practice on Friday to turn some laps with Sophia... - that sounds so much better than play with toy cars, thanks Dale.
timmay70 is offline
Old 09-10-2008, 08:14 AM
  #93
Carl Giordano's Avatar
Trader Rating: 32 (100%+)
Smile
Quick Question.
Does it make sense to convert a Rev 4 into a Pro10? Just thinking if there is a cost saving to convert as all you'll need is the Pro-10 chassis and rear axle / hubs?
Basically, I have an outdoor Rev 4 chassis just sitting in my hobby room doing nothing...
I checked the website and was unable to find a conversion Kit...perhaps someone from Speedmerchant can respond directly...
IMHO: it would make sense as I'm sure there are tons of racers who have unused 1/12th scales.
Odpurple: How's the project Rev 5 coming...let me know when its ready to rumble as its starting to get cold here on the east coast...besides, I'm going to ask you for your help on the Pro-10 project shortly.
Carl Giordano is offline
Old 09-10-2008, 10:10 AM
  #94
timmay70's Avatar
Originally Posted by Carl Giordano
Quick Question.
Carl, the rear pod on the Pro-10 is also wider than the Rev.4 pod. It better accommodates brushless motors, and also centers the mass within the pod. I am sure that you can have it work, but you may want more than just the chassis plate and nerf wings... I am sure that is all you need to convert an old Rev.4...
timmay70 is offline
Old 09-10-2008, 10:38 AM
  #95
The tweak brace is not going to be the same either. Figure a 12th scale is about 172mm in width where as the WGT car is 200mm in width.
JoelV is offline
Old 09-10-2008, 11:09 AM
  #96
timmay70's Avatar
Thanks Joel, good call.
timmay70 is offline
Old 09-10-2008, 11:22 AM
  #97
thanks for the responses...they all make sense...which is why I asked if a conversion kit was available.
I thought the Rev 4 motor pod would work as i noticed somewhere it lloked the same as the entry level 1/10th scale on-road chassis...in any event I figured once a brushless was wired into the Rev 4 motor pod (which was neatly done by ODPurople) i could transfer to the 1/10th scale as i do not expect to have to replace the motor frequently.
I'll probably just pick-up a new kit but thought to ask the question.
Old 01-25-2009, 05:51 PM
  #98
Trader Rating: 16 (94%+)
Just got my SpeedMerchant Pro-10 on Friday, got it built in record time and on the track the next morning for Saturday's race. All I got to and holy crap, this thing was a BLAST to drive.
Could some of the other SpeedMerchant Pro-10 drivers please post their setups, as there are none to be found.
My setups was the following:
HB Cyclone 12 shock with Assoc. 50wt oil and 14lb Red Spring
Red Tube Spooge
.23" Side Springs - tweak screws backed all the way out
.22" BMI Linear front Springs
Team Tamale Aluminum Inline steering blocks - wide
Team Tamale Aluminum Bulkheads
3.5mm Front Ride Height
3.5mm Middle Ridge Height
4.0mm Rear Ride Height
Pod Droop = 2mm
Front/Rear Jaco Lilac Spec Tires at 56.0mm
1-deg Caster
3.5-deg Camber
Caster/Camber stand-offs: Stock Brass + 3mm Alum Spacer
Corvette C6 body
kn7671 is offline
Old 02-10-2009, 04:24 PM
  #99
Nobody has any setup information for the SpeedMerchant Pro-10 WGT car?
kn7671 is offline
Old 02-10-2009, 04:46 PM
  #100
Kelly, come see me this weekend. We will get you going.
teamtamale is offline
Old 02-10-2009, 05:27 PM
  #101
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Pod Droop = 2mm
i'm not a team driver, nor did have i run my F-10 with inline blocks yet but i do have two suggestions:
#1 - cut your tires down to 55mm -- the lilacs don't wear and the car will handle better (assuming carpet)
#2 - your car seems a little low. i think 4mm is the minimum ride height per the rules: http://worldgtrc.com/
you may also choose to use a heavier front spring. i think i've run associated .022.
hanulec is offline
Old 02-10-2009, 07:26 PM
  #102
odpurple's Avatar
Just thought I would share a shot of my Formula 10.
It just might be the most fun you can have with an RC car
odpurple is offline
Old 02-10-2009, 09:00 PM
  #103
tpczx6's Avatar
Also see Yang at your track he has setup you want. also if you go to their website the winning setups are posted.
tpczx6 is offline
Old 02-10-2009, 09:04 PM
  #104
tpczx6's Avatar
Needs more PURPLE
tpczx6 is offline
Old 02-10-2009, 09:06 PM
  #105
tpczx6's Avatar
Larry I need some parts send me an Pm also glade hear you running some 1/12th scale
tpczx6 is offline
