Old 08-22-2009, 10:26 AM   #1471
PartTime's Avatar
Originally Posted by Ultramarv View Post
Anyone have any close up pictures of their 125r's with all the electronics and batteries installed???
I've finished building mine and now I'm installing all the electronics. Having a hard time deciding which way all the wires and components should go/sit...
I have an LRP SPX, spektrun SR3500, and a LRP 13.5t X11 motor. I am also installing a Novak Smart Booster... anyone else running this? Any suggestions on how and where to mount the smart booster???
Any help and suggestions would be GREATLY appreciated. Any piictures would surelyhelp too!!
I can't wait to get this thing running!!!
Marv
The guys I see running the novak booster have mounted them on top of the servo. All of them.
Hope this helps. Here is a pic of my old car. Let me know if you need any other pics.
DK
PartTime is offline   Reply With Quote
Old 08-22-2009, 10:30 AM   #1472
PartTime's Avatar
Anybody running crc rubber? I have been playing with tires latley and have a problem with the crc rears. I cant get the rear skinnier than 173mm. I would have to shave the left hub .020 to get it to 172mm or am I missing somthing? No shims on the left and 3 on right. The track width is even left to right but just too wide. Maybe a skinnier left side hub?
DK
Old 08-22-2009, 11:05 AM   #1473
jkirkwood's Avatar
Originally Posted by xrayeddy View Post
Anyone know of a wide front carbon fiber bumper for this car? I had a Gen X with a wide bumper but didnt' know who manufactured it.
THanks
I use this one. It's a direct fit, just cut/sand down to fit the profile of the body you are running.
https://www.ssl-stormerhobbies.com/c...=ns&pn=CRC3260
jkirkwood is offline   Reply With Quote
Old 08-22-2009, 11:15 AM   #1474
Trader Rating: 96 (100%+)
I bought a Gen X used off here and it had a carbon fiber wide bumper, however, Im unsure of who made it. A foam bumper will not withstand my driving skills.
Like this:
K.Copeland is offline   Reply With Quote
Old 08-22-2009, 12:01 PM   #1475
mangoman's Avatar
That is one wide bumper!
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-22-2009, 12:23 PM   #1476
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Like this:
I thought the same when I started driving. I made a C F bumper for my 12th and it worked great till about 2 weeks after installing it, it pulled the mounting screws through the chassis requiring replacement. I tried again with a kydex version and experienced the same problem. I now have the shorter version of the CRC foam shown and I think you would be best off with that option. It backs up to the suspension arms and is made of some substantial foam.
Just an FYI for you gram counters, the smaller CRC foam bumper is 6 grams compared to 12 for the wide bumper.
Old 08-22-2009, 12:23 PM   #1477
jkirkwood's Avatar
I agree but I was racing at a track with pvc pipe and if I barely clipped the pipe on the front it would just hang the body and go up under the pipe. With this bumper no more hanging on the pipe and the body lasted much longer. CRC makes a shorter one too but for club racing I tend to like the wide.
For a big race I would probably go with a bit less front bumper. Although the car still weights 731g with the trued tires. 473g with new.
Old 08-22-2009, 03:07 PM   #1478
Thanks DK!!!
Your pix of your car helped me out!!! I will try and route my wires and get everthing cleaned up!!!
Marv
Big Marv
Ultramarv is offline   Reply With Quote
Old 08-22-2009, 04:31 PM   #1479
Here's a tip I found to get various thickness spacers for use in adjusting shock travel in the center shock. The standard spacer is 4mm. I happen to prefer a 2.5 to 3 mm spacer. So I use pieces of antenna cut to length. To do this I make a guillotine using an aluminum spacer the same thickness as my desired spacer thickness. I set the spacer vertically on my pit table and close off one end of the hole in the spacer with my droop gauge (any hard flat surface will do) Then I place the end of the antenna tube on the other end of the spacer and use an Exacto to slice down on the tube, and Viola! A 3 mm internal shock spacer. If you're really organized like me you make each .5 mm length out of a different color tube and keep several of each size on a small container. The main reason I do this to allow the shock to compress completely without creating excessive rear pod droop.
Old 08-22-2009, 10:05 PM   #1480
EricF's Avatar
That's a good tip Andrew... now I need to buy more antena tubes.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 08-22-2009, 10:24 PM   #1481
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Like this:
Im pretty sure thats a bumper off of a Hyperdrive 12th Oval car.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 08-22-2009, 10:41 PM   #1482
t4m1y4niac's Avatar
guys, want to ask...can i upgrading my R5 to R5.1 ?????
what items should i buy?
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 08-22-2009, 11:29 PM   #1483
EricF's Avatar
Default 12R5 to 5.1 parts list
Correct numbers for the other R5.1 parts are
8536 and 8537 are the correct bulkheads
4687 Motor mount standoff
4688 Graphite shock mount
Old 08-22-2009, 11:55 PM   #1484
t4m1y4niac's Avatar
thanks EricF...i'll try to find those items..
Old 08-23-2009, 04:13 AM   #1485
Joost K.'s Avatar
To completely upgrade a R5 to a R5.1 you will also need the following parts:
8511 FT Lower Pod Plate
4608 FT RC12R5 Hub (brushless)
4609 RC12R5 Thrust Cone (brushless)
The RC12R5.1 used the wide brushless rear pod so if you have a box-stock RC12R5 you will need these parts also. Otherwise the graphite shock mount and the motor mount standoff will not fit. Offcoarse, if you use a thrust bearing like the Slapmaster you won't need the Thrust Cone but that would be obvious I guess...
I have the T-plate conversion for the RC12R5 and for this 12th scale season I am going to convert that chassis to a 5.1 rearpod WITH T-plate. I have to custom make a new lower pod plate but that won't be a problem. When it's done I will show you guys some pictures...
Joost.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
