Old 08-04-2009, 11:37 AM   #1381
Sideways_1's Avatar
Trader Rating: 141 (100%+)
Originally Posted by Sean Cochran View Post
Ko and Futaba both have servos that are direct fit.
Airtronics also but I heard that one might have been discontinued.
So like a Futaba 9650 or KO 951 ??
Sideways_1 is offline   Reply With Quote
Old 08-04-2009, 01:12 PM   #1382
EricF's Avatar
EricF is offline   Reply With Quote
Old 08-05-2009, 06:42 AM   #1383
avs
avs's Avatar
the futaba 9602 is the same size as the 9650 but is a faster, lower torque, analog metal gear with less freeplay compared to the plastic geared digital 9650.
the 9650 with MKS's metal gears is a popular servo for 500 heli's. i just installed a set of these in my 12scale but haven't run it yet. on the bench it seems to work ok and much reduced lash. (i don't have a precise measurement but it seemed that half the lash was from the servo/horn connection and the rest from the internal geartrain)
avs is offline   Reply With Quote
Old 08-05-2009, 06:47 AM   #1384
Damit's Avatar
Trader Rating: 22 (100%+)
Default MG 9650
avs,
Do you have a site or link to MKS, I am interested in have a look at these gears.
Chris
B6d 2wd / B64d 4wd - SJF01 Street Jam F1 - Tamiya Mini v2
Futaba-HW-LRP-Lunsford-Reedy/Associated
South Australian Member: AERCCC #16 and ARCR 9098
Damit is offline   Reply With Quote
Old 08-06-2009, 07:03 AM   #1385
avs
avs's Avatar
Originally Posted by Damit View Post
avs,
Chris
the servo is the MKS 9660, the mfg site is:
http://www.mks-servo.com.tw/NARO-BK1.htm
some sources:
http://www.mtahobbies.com/
i don't see it right off on their website but i just bought a set from him, i know they stock them.
i think most 'heli' specialists will know or have them , like:
http://www.helidirect.com/mks-metal-...vo-p-11040.hdx
Old 08-06-2009, 05:42 PM   #1386
Hello all!!
I'm new to the 1/12th scale scene and I just bought a 12r5 and have a couple questions after reading thogh hundreads of post... sorry if I ask a question that has already been answered.
On the 12R5 that I am building... I will be running 1s lipo. I pre ordered the Reedy 4600mah 3.7v 1s pack and was wondering if there will be any modifications that need to be done to the chassis???
Also, I have yet to buy a servo and was wondering if there are any other servos other that the Futaba S9650 and the KO PDS951? I see that Team Orion has a low profile servo out but I'm not sure if it will fit... the dimensions are 40.8 x 20.2 x 25.4mm. What servos are you guy running??
Last, what are the part numbers for the side springs and the rear springs that are options for the 12r5???
Thanks for all the help in advance!!!
Marv
Big Marv
Ultramarv is offline   Reply With Quote
Old 08-06-2009, 05:50 PM   #1387
Ooops!!! One more question I forgot to ask...
I have been running a Spektrum module and receiver in my Airtronics M11 for the past 4 years... are there any issues with 2.4ghz in 1/12th scale cars??? I remember reading in the magazines a few years ago when DSM was just starting out out that carpet cars had problems with static. Is this still the case??? Will I need to run my 75mhz receiver and module???
Thanks again!!
Big Marv
Old 08-07-2009, 04:13 AM   #1388
HaraR40's Avatar
Trader Rating: 33 (100%+)
Default ...
Ultramarv
I'd get the Futaba or KO that people are saying. I got a cheaper hitec but it does not line up with the holes very well. for the sake of $55 the futaba is very good and i will be buying one myself.
as for spring, i just bought these sets as i was told they will fit and i could not find any associated ones in kits.
http://cgi.ebay.com/Calandra-Center-...d=p3286.c0.m14
http://cgi.ebay.com/Calandra-Rear-Si...d=p3286.c0.m14
Otherwise look in your parts manual and search the part numbers on towerhobbies.com they have all the associated ones seperate.
i run a spektrum S3000 receiver in my 12R5 with a DX2.0 handset and have no problem at all.
as far as the lipo goes. i know the SMC has the little dips in the case to sit in where the cells would on the chassis. i beleive some people are glueing on a lexan sheet of some sort which has these dimples to keep the battery stable. but i only run 4-cellls so i could not say for sure......
hope all goes well for you. hope it goes well for me too as i just started
Full alloy Micro-t, orion 10,300kv brushless
Corally RDX PHi Drifter - 8.5T Lipo
Axial AX10 Crawler, Vanquish chassis/knuckles, tekin FXR/35t, lipo, DNA dig, HB rovers...
HI Blitz ESE, 10.5T, Lipo
HaraR40 is offline   Reply With Quote
Old 08-07-2009, 06:50 AM   #1389
Trader Rating: 45 (100%+)
Anyone know if the new SMC 4900 40C 1S LiPO will fit under the shock on the 12R5?
Apex is offline   Reply With Quote
Old 08-07-2009, 07:43 AM   #1390
Trader Rating: 14 (94%+)
yes it does
j manikis is offline   Reply With Quote
Old 08-07-2009, 09:58 PM   #1391
PartTime's Avatar
The Phantom (TP) 5000 40c fits with the deans right under the shock.
PartTime is offline   Reply With Quote
Old 08-08-2009, 04:22 PM   #1392
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default lipo
the POWER PUSH 5000 mah 40c works with plenty of room in the car
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 08-09-2009, 10:25 AM   #1393
What is a good starting point for gear combo (pinion/spur) the 12r5???? I will be running 13.5t LRP X11 vector and a 3.7v 1s lipo.
Thanks!!
Marv
Big Marv
Old 08-09-2009, 02:54 PM   #1394
Hey Marvin,
I just finished my 12R5 and will be taking it to VRP this Thursday night to put some laps on it. If you can, try and come down.
I'm going to start with mine geared 42/75 and see what happens. It's a Tekin RS Pro, Fantom 13.5, Fantom 5000 40c LiPo combo. Tires are 44.5mm rear and 43mm front for now. It's been a long time since I've run a 1/12th scale car. Can't wait to get this on the rug!!
Curtis
cmenard is offline   Reply With Quote
Old 08-09-2009, 03:09 PM   #1395
Thanks Curtis!!!
I just got mine and just started the build. Not sure if I can make in Thursday down to VRP but I plan on running as soon as possible. Need some track time to learn how to drive it!!!
So I guess I shouldn't use the stock 96tooth spur that came with my kit, huh???
Steve Smith and I plan on running at Nexus and VRP (if they start racing 1/12th scale).
Thanks for you help. I'm sure I'll be asking you a million questions. I know you are a great driver and I know Mark Johnson is too!!!
Marv
Big Marv
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
