Old 07-20-2009, 04:57 PM   #1366
AE-Reedy
Originally Posted by obi wun View Post
How do you properly check the alignment of the rear pod...and by the way, big thanks to everyone helping me out with this 12r5...when I get it right i will hopefully be competitive with it ...
Andrew is right in his reply but I prefer to just unscrew the cross brace from the chassis and un-bolt the pod plates from the bottom graphite plate. Swing every thing out of the way and feel just the movement in the bottom plate. The graphite piece should be able to move up and down very freely. Side to side should be smoooth with no notchy feel as it pivots.
If it doesn't feel right loosen the 2 screws that hold the center pivot to the chassis. The best way to set the alignment is to place the chassis and pod plate on a smooth flat surface and then tighten the the screws back up. In a pinch you can also just apply light pressure to the center pivot holder toward the rear of the car and tighten the screws. Check the pod movement again to verify that it feels right.
This pod alignment is very important to getting your car to handle right. It doesn't seem to change much after you get it right. If you have a major impact it is always a good idea to check this.
Sean Cochran is offline   Reply With Quote
Old 07-26-2009, 06:27 AM   #1367
Trader Rating: 23 (100%+)
Sean
In you 1 cell lipo set-up posted, you stated no spacers behind the servo and use silver ballstuds. Is this correct and did you leave the ballstuds facing towards the rear of the car?
bmcallister is offline   Reply With Quote
Old 07-26-2009, 11:17 PM   #1368
HaraR40's Avatar
Trader Rating: 33 (100%+)
Default rollout?
What rollout should i aim for?
i have a 10.5t purple roche brushless motor and will be getting a GTB 4-cell speedy running 4cell nimh batteries. Spur gear is a 72t and will be using Jaco Prisms.
We are going to be playing around with track designs on a twin tenis court size area. i guess that would make it a medium size track?
i hope this is enough info, if someone can please help?
Alex
Full alloy Micro-t, orion 10,300kv brushless
Corally RDX PHi Drifter - 8.5T Lipo
Axial AX10 Crawler, Vanquish chassis/knuckles, tekin FXR/35t, lipo, DNA dig, HB rovers...
HI Blitz ESE, 10.5T, Lipo
HaraR40 is offline   Reply With Quote
Old 07-27-2009, 04:51 PM   #1369
AE-Reedy
Originally Posted by bmcallister View Post
Sean
I use a JR servo and drill the chassis for my own mounts. The most important thing is the steering rod angle. It needs to be straight or angled forward just a little. Use whatever combination of spacers and ball ends it takes to get the correct angle.
Old 07-29-2009, 11:49 AM   #1370
Does anyone sell the parts for the yokomo version of the 12r5?
Old 07-31-2009, 08:04 PM   #1371
tattooedchef's Avatar
Default yup
yeah rcmaket.com they have them for about 51$ with shipping i got them there great
Freind don't let freinds drive losi
RC8 almost FT,RC8T almost FT, FT RCB44, FT RC10B4, RC10SC, FT RC10TC5R, FT RC12R5,E-REVO Brushless Edition, DX3R Specturm
tattooedchef is offline   Reply With Quote
Old 08-03-2009, 01:19 PM   #1372
Send a message via AIM to ERTRACHTER
Hey Sean Cochoran ygpm
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 08-03-2009, 03:58 PM   #1373
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
could somebody post a picture of the car with a 1 cell lipo installed.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 08-03-2009, 04:48 PM   #1374
jkirkwood's Avatar
I've since changed to 13.5. The 17.5 is too slow for me with 1c lipo.
jkirkwood is offline   Reply With Quote
Old 08-03-2009, 05:17 PM   #1375
bigb11's Avatar
do you use a lipo tray?
Old 08-03-2009, 05:24 PM   #1376
What kinda bumper is that one? Im using the one from Parma but is smaller than that one on the picture.
A.Vazquez
AVazquez is offline   Reply With Quote
Old 08-03-2009, 06:31 PM   #1377
jkirkwood's Avatar
No, weight limit is 730g. The car weight 731 grams with cut tires and light weight body. With new tires 742g. Took me a few packs to find a setup I like with the lighter weight but I think I about got it where it needs to be.
A.Vazquez
It's the CRC bumper (CRC3260). The body post holes are direct fit. All you will need to do is shape the bumper to fit under the body.
https://www.ssl-stormerhobbies.com/c...=ns&pn=CRC3260
Another option is CRC3259. It is slightly smaller and only covers the front of the chassis. I like the wide to support the entire front of the front body but it does weight a bit more.
Old 08-03-2009, 09:09 PM   #1378
Sideways_1's Avatar
Trader Rating: 141 (100%+)
Wow my eyes hurt after 92 pages
So without drilling out the chassis for fitment etc. what is the concensus for best out of the package servo?
Sideways_1 is offline   Reply With Quote
Old 08-04-2009, 11:15 AM   #1379
mangoman's Avatar
Default Diff rings?
Hi peoples, ive got a new 12r5 and i purchased a bunch of diff rings with it.
Ive checked the part number a number of times and i have the right part but instead of being D rings they are just plain circles.
IE. Just like this.
http://www3.towerhobbies.com/cgi-bin...625+&search=Go
Can anyone tell me what the deal is with this?
Thanks,
Martin
PS. If anyone has any build tips (things to look out for) it would be appreciated!
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-04-2009, 11:17 AM   #1380
AE-Reedy
Ko and Futaba both have servos that are direct fit.
Airtronics also but I heard that one might have been discontinued.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
