Old 06-15-2009, 01:53 PM   #1276
HB Moose's Avatar
Originally Posted by andrewdoherty View Post
Hopefully before Vegas . . .
Team Associated now has a carpet track near them. (OCRC) Hopefully we can talk them into publishing a one cell lipo on carpet setup soon.
If not I'll be forced to spy on them in the pits.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 06-15-2009, 02:10 PM   #1277
AE-Reedy
Don't have any problem letting everyone know about the set up. I went and ran some packs on Saturday after racing and I'm still not seeing where the car requires the set up to be changed much from 4 cell. I did try .018" front springs and gold spring with 25 wt oil in the center shock. Mostly I was trying to find some way to smooth out the "waves". The biggest issue I'm having is with tires and the "build up" I am getting on the fronts. If time allows I might race on Tuesday.
Sean Cochran is offline   Reply With Quote
Old 06-15-2009, 02:55 PM   #1278
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
What kinda tires are you running? Whats the grip like at OCRC? We've found saucing the whole fronts helps keep the tires from glazing. That and making sure nothing but paragon is used on the carpet. We used to spray traction action to get more grip, until we found it was causing glazing.
Old 06-15-2009, 04:00 PM   #1279
lbckevin's Avatar
Trader Rating: 82 (99%+)
Andrew...
At OCRC. ( ocrcracway.com ) we run only Jack the Gripper tire sauce. Its a med - high bite CRC carpet. We are having the front tires glaze up. The glazing occurs on the outer half of the tire, where no sauce is applied. We have to clean it each run with motor spray...Any other suggestions...
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is offline   Reply With Quote
Old 06-15-2009, 04:18 PM   #1280
Default Lipo receiver pack
Couple of questions for those running a receiver pack. If I use a lipo receiver pack 300mah do I have to charge it in a lipo sack? Second question is how and where are people mounting the receiver pack? especially if it has to be removed and charged in a lipo sack any quick release for recharge?
Cubic$Racing is offline   Reply With Quote
Old 06-15-2009, 05:18 PM   #1281
AE-Reedy
ROAR rules exclude Rx packs from the lipo sack rule. Just mount it any where
convenient.
Old 06-15-2009, 05:50 PM   #1282
Originally Posted by lbckevin View Post
Andrew...
I would see if I could run a harder front tire and sauce the whole thing and see if you still got the glaze. I suspect if you sauced the whole tire you run currently you'd get some serious over steer.
We had the exact same problem with the to make it work. glazing on the portion of the tire we didn't sauce. It went away once we started saucing the whole tire and made the adjustments to our setups. Were in a little different situation though as we are usually looking for more grip as we run on med bite carpet. What compound tires are y'all running in 13.5 12th?
I don't know how well everyone at your track sticks to the jtg rule, but if you've had different compounds in the carpet you might try giving it a good vacuuming and then make sure nothing but JTG is used and see if the glazing goes away. When we realized the traction action we were spraying was causing the glazing we used our trusty rainbow vacuum on the whole carpet. It sucks up pretty much all the groove and then we started over only spraying acetone and paragon when needed. We haven't seen the problem since then.
I think I saw someone say that roar would not be requiring the use of a lipo sack to charge the receiver packs, and I don't think Scotty is either. I could be wrong though. If we do have to remove it I would probably use velcro or the like . . .
Old 06-15-2009, 07:30 PM   #1283
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
i couldnt wait around for roar to change in time for nats (in our backyard). so i'm offloading mine. i know i'll kick myself in the end. but oh well wouldnt be the 1st time.
the ohp booster is proving itself well over in this neck of the woods
R
UltegraSTI is offline   Reply With Quote
Old 06-16-2009, 08:01 AM   #1284
wingman2's Avatar
Hi guys, does anyone happen to know if AE are going to release their 12th car with the new rear pod from the oval car as part of the kit setup? Or will it be a seperate up grade? I am thinking of getting the chassis but will wait a little bit longer if the new parts are going to be included. Cheers guys, Chris.
wingman2 is offline   Reply With Quote
Old 06-16-2009, 08:04 AM   #1285
PartTime's Avatar
If they havnt put the 10r5 rear pod in the kit yet I wouldnt hold your breath on the other pod being in the kit.
DK
PartTime is offline   Reply With Quote
Old 06-16-2009, 08:38 AM   #1286
R
Whats an OHP booster? link .. .?
Old 06-16-2009, 08:59 AM   #1287
Registered User
UltegraSTI's Avatar
contact OHP (thru lefthander), voltage booster instead of a rx battery. its the ticket.
R
Old 06-16-2009, 10:42 AM   #1288
R
I searched and looked but I didn't see any mention of anything OHP on the lefthander site or of anything other than the Novak booster. Am I missing something?
www.lefthander-rc.com
Old 06-16-2009, 02:31 PM   #1289
AE-Reedy
Just a quick list of the set up I used on Saturday at OCRC.
Jaco Prism Pink front with JtG 1/2 front 43 mm
.018" springs with 30k on kingpin
5 Dgr. re-active
+1.80 caster
3mm spacer between arm and blkhd
.015" spacer on axle
4.4mm ride ht.
Center shk
AE 25 wt. with Gold spring
Shk mnt pos 2
lipo mounted forward
Jaco Prism Yellow rear JtG full Rear 45.5mm
Gold side springs w AE 35 wt side shock
10R5 rear pod rear width 172mm
4.8mm ride ht.
Protoform Speed 12 lwt
Lrp SPX w LRP 13.5t 49/78
If I forgot anything just ask and I will fill in the blanks.
The only 2 changes from my "normal" set up is the .018" front springs and the gold spring and oil in the center shock. Both of those were more to try and help the ride through the bumps.
Old 06-16-2009, 02:33 PM   #1290
Registered User
UltegraSTI's Avatar
must not be up there yet. supposed to be back in 2wks. contact the folks at OHP for them.
http://ohiohobbyplus.com/
R
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
