Old 06-08-2009, 10:10 AM   #1246
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by PutAwayWet View Post
Are you running lipo now, or are you going with 4-cell? I've been running lipo in my R5 for several months and it's working great. The setup you describe is definitely not for lipo.
Hes got a 1cell Li-Po and a 13.5
I'd love to hear about your set-up if you would ?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-08-2009, 11:14 AM   #1247
PartTime's Avatar
Yes Im running lipo now. So whats bad, the setup on it or the one Im changing to?
I have a little bit of time on a carpet knife with lipo and am thinking most of the changes I did to that car should effect this car the same?
DK
PartTime is offline   Reply With Quote
Old 06-08-2009, 05:10 PM   #1248
PutAwayWet's Avatar
DK
Well, the one on it now is definitely not what you want, though you've gathered that. Here's mine:
Weight: 735-740g (depending on the tires)
Ride Height: 4mm
Tires F/R: dbl pink/dbl pink
Center Spring: Blue
Shock Oil: 25wt
Side Oil: 20wt
Side Spring: Silver or Green
Front Spring: 0.18
Kingpin lube: CRC white
Camber: 1 deg.
Caster: kit spec
I've run that on both Jack tracks and our current Paragon track (so much better, btw, if you ever get the chance.)
Straight off, try the green side spring, and if it's a little soft, go to the silver. I like the green, though. The car really settles into the sweepers. I think you're right about the CK, it's more alike, being a link car, than otherwise. Tell me how it works for you.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 06-08-2009, 06:24 PM   #1249
AE-Reedy
Regarding lipo set ups;
We haven't had much oppurtunity to do testing with the lipos yet.
We only just got a track we can run at, normally the only time we race 12th is at the big carpet races.
From the little we have run we haven't seen that the car requires much in the way of set up changes. We did test in Tuscon last month but the grip wasn't very high. We found the cars to be much better with lipos compared to our 4cells and we didn't make any changes.
We found that the mass balance of the car is basically right in the center of the battery tray so switching from a heavy 4 cell to a light lipo the balance of the car stays relatively the same. I'm sure with more time to run we might find some little things that will help, probably with the dampening.
Only when you have good competition can you really tell where you stand.
As soon as we have any thing confirmed for lipo we will post it.
Sean Cochran is offline   Reply With Quote
Old 06-09-2009, 02:01 AM   #1250
Tomesz's Avatar
anyone know can be brushless pod used on t-plate conversion? i ask cuz for that is need upper and lower plate, whose is only for linkage version....
yeah thats not about lipols, sorry
Serpent 720 09
Tomesz is offline   Reply With Quote
Old 06-09-2009, 11:09 AM   #1251
Yeah , you guys must be running on ash fault outside or something .
I've felt a tremendous difference with only changing the battery on carpet .
It needed a lot of changes. That set-up above looks pretty good to me!
Old 06-09-2009, 11:14 AM   #1252
PartTime's Avatar
putawaywet....thanks. I will write that down and take it with me to the track. Will report my findings.
DK
Old 06-09-2009, 11:29 AM   #1253
AE-Reedy
What kind of handling problems are you guys seeing when you change from 4 cell to lipo?
Old 06-09-2009, 11:34 AM   #1254
chris moore's Avatar
Trader Rating: 85 (99%+)
Sean, were you running at CH in Tuscon?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 06-09-2009, 11:36 AM   #1255
Basically it pushed . The car wouldn't rotate.
Old 06-09-2009, 11:38 AM   #1256
I have found that on high bite carpet going to a dpl pink tire helped this issue, with yellows the rear gets too locked in
Sponsered by:
Old 06-09-2009, 11:44 AM   #1257
AE-Reedy
Yes we ran 3 days at CH and I have run 2 packs on the track here at OCRC.
I'm going to try and get there to run more this week.
Old 06-09-2009, 12:57 PM   #1258
PartTime's Avatar
Not really a problem with handling, just a little diffrent. The car wont rotate as fast on corner entry as it would with the 4cell. Less weight back there and you have less weight to swing the rear around with. Plus when you get off the power in a corner it wont transfer the weight as fast. Normally I need a little lube on the kingpins to slow that down. With the lipo no lube needed.
My first test drive with the R5 and lipo had purple frt/dbl pink rear. The car needs more mechanical grip. The last 4 mins it pushs a touch and is lose a touch. Just need to soften it up and let it transfer what little weght is left.
DK
Old 06-09-2009, 01:02 PM   #1259
Default sean
could please post your set-up ocrc when you get a chance after you run
there, my son and i have switch over to electric from nitro and run at ocrc twice amonth there with r pan cars. thks 4 your support
isuzuguy is offline   Reply With Quote
Old 06-09-2009, 02:38 PM   #1260
AE-Reedy
DK
Given the way people use tires these days those compounds are hard. That would explain your low grip. I ran pink/magenta fronts and pink rears at all the races last winter. I like yellow rears also but had many problems with them chunking or tearing during the runs.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
