Old 05-09-2009, 08:04 PM   #1216
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
What turn motors are you guys using in your modified class?
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 05-09-2009, 08:56 PM   #1217
GWH74's Avatar
Default Lipo packs
What is the minimum clearance under the rear shock on the RC12R5?
Mine is on the way and i was just checking if one cell of the IP saddle pack Lipo would fit under.
Will the SMC one will have much lower COG i already have a few saddle packs i can use for practice.
GWH74 is offline   Reply With Quote
Old 05-10-2009, 06:57 AM   #1218
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by silverfrancis View Post
How about if you put this with the yeah racing brainless 13 turn brushless motor. Does it perform as well as 4 cell nimh.
With the weight of the battery being very light , the set up changes and the gear ratio goes through the roof . Try it with a roll out of 3.1 inches or 78.75mm. It wont have the bottom end you are used to but it will corner like a dream. Good luck with those friggin' archaic round cells.. they are becoming a thing of the past.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-10-2009, 09:22 AM   #1219
PartTime's Avatar
I have run an orion and novak 13.5 with a smc 1c lipo and it NEVER left me wanting more power. Even against guys that can put it in the A at national events !!! It is a diffrent setup if you run light but my car wighted to 800 grams could run the same setup as a 4cell. At 720 grams I had a few changes to make to get the corner speed out of it.
3.2 roll out seems to be the sweet spot for most motors. I would start there and see how it acts.
DK
PartTime is offline   Reply With Quote
Old 05-10-2009, 09:27 AM   #1220
Canuck's Avatar
Trader Rating: 25 (100%+)
DK
Same here, found 3.2 rollout to be sweet ! Using DUO 13.5 in middle timing and boost at 20 on Tekin RS.
Canuck is offline   Reply With Quote
Old 05-10-2009, 10:34 PM   #1221
lbckevin's Avatar
Trader Rating: 82 (99%+)
what pinion and spur are you running with the 1 cell lipo...just getting an idea.
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is offline   Reply With Quote
Old 05-11-2009, 01:27 AM   #1222
silverfrancis's Avatar
I'm new to all the lipo business in rc cars. What is the required gear to get the set up working. Is there a diagram that i can look at or a guide of some sought. Also the yeah racing esc only supports 2 to 3 cell lipo. Is it still possible to go ahead with the set up you have suggested.
For Technology news visit: www.technific.com
silverfrancis is offline   Reply With Quote
Old 05-11-2009, 03:52 AM   #1223
Canuck's Avatar
Pinion = 42
Spur = 72
Rear tires 44.3mm
Rollout 3.2
You can start with rear tires at 46 mm and front at 44mm and drop pinion to 41 for a rollout of 3.23
This setup works fine for me with a Tekin RS version 194 firmware and boost at 15, motor at middle timing on a DUO 13.5.
Also use a voltage booster.
Hope this helps.
Old 05-11-2009, 05:06 AM   #1224
please advise on what sort of setup changes you guys are making to account for the lighter lipo pack? Softer springs? softer tires? what?
vafactor is offline   Reply With Quote
Old 05-12-2009, 12:59 PM   #1225
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
I am curious about this also. With the ROAR lipo rules, I will probably be getting a 12R5 to race this winter with LiPo and a 13.5.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 05-12-2009, 02:33 PM   #1226
Trader Rating: 45 (100%+)
I'm surprised you're asking these questions. After all you are the "Godfather"! I'm still in the process of putting mine together.
Apex is offline   Reply With Quote
Old 05-14-2009, 07:20 AM   #1227
GWH74's Avatar
Default Yokomo
RC Market in HK has the Yokomo rear bulk head brace in stock. US$25
Old 05-14-2009, 09:05 AM   #1228
PartTime's Avatar
Start with a step softer spring, side and front. Maybe a touch softer side damping and go from there. Or you could just bring the car upto 800 grams with a weighted plate and drive it with the same setup as 4cell stock.
DK
Old 05-14-2009, 09:21 AM   #1229
PartTime's Avatar
So what are the roar rules for lipo in 1/12th?
DK
Old 05-14-2009, 09:49 AM   #1230
EricF's Avatar
DK
They made lipo legal for 1/12, wgt classes. 1/12-17.5 stock, 13.5 spr stock, mod
E
EricF is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
