Old 03-14-2009, 08:32 AM   #1156
Canuck's Avatar
Trader Rating: 25 (100%+)
Originally Posted by theisgroup View Post
as most will tell you 46.5 is quite large for a rear tire. But i will start mine at that size for club races. usually the fronts I like them to be 2mm smaller. it seam that any less stager and the car pushes. I would go to a larger stager to add steering, but not much more then 2.5mm.
also if you tend to hit boards, you might want to cut them a little smaller. like say 42 front and 44 rear. just to help reduce chuncking. large tires are easy to chunk.
one more helpful advice is to glue the bead on the tires. expecially the yellow. they tend to chunk quite easily. I have chuncked yellow with no board hits. so I try to ca the bead almost every run just to reduce the chunking.
What's the bead on the tire ? Is it the sidewall ?
Do I also CA the fronts or wait and see how they perform ?
Canuck is offline   Reply With Quote
Old 03-14-2009, 08:40 AM   #1157
Uga
Uga's Avatar
BTW it also matters a lot what brand CA u r using for sidewalls, some of them just peels off after 1-2 runs. I have already saved bunch of money on tires with the CS SideWall Protection glue. The next best thing is the Loctite Super Attak Precision glue, which you will probably find in any department store. Perhaps other racers have found something that works just as well.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 03-14-2009, 12:14 PM   #1158
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Canuck View Post
Here's a quick question maybe the Oval guys can help me out ?
I want to use a Novak GTB 4-Cell Competition Brushed/Brushless Electronic Speed Control with my 12R5 1/12 pan car.
Will it work with the SMC 1S lipo and TQ booster ? Do I disable anything for the lipo cutoff because it is 1 cell ?
How about wiring , anything special with this hookup ?
Steve
Steve,
I know a few guys running the GTB 4 cell with no rx pack or booster. IF you want to run a booster, there's no special wiring needed. Attach the booster input leads to the smc battery, plug the booster into the receiver, leave the GTB switch OFF. I don't know if the TQ booster has its own switch, if it does, that will turn everything on. If it has no switch, then plugging it into the receiver will turn everything on.
I don't know if you have to disable the voltage cutoff on the novak... I don't even know if the 4 cell novak has a voltage cutoff.
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-14-2009, 01:59 PM   #1159
Canuck's Avatar
OK thanks Trips.
Old 03-14-2009, 08:36 PM   #1160
theisgroup's Avatar
where the foam meets the wheel. i don't glue the sidewalls. I think that does not do much in saving the tire from chunking. actually I think it causes it to chunk more. i just make sure the foam stays on the wheel.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-16-2009, 01:41 PM   #1161
w w w.teamyokomo.com/jpn/news/order_sheet/090311_rc12r5we.pdf
whats new on this one?
defencex is offline   Reply With Quote
Old 03-16-2009, 01:52 PM   #1162
EricF's Avatar
the center brace that goes below the side dampner. Also alumn. side spring holders. All else looks the same w/o really looking for anything that different.
E
EricF is offline   Reply With Quote
Old 03-16-2009, 05:40 PM   #1163
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Looks like the brace, side plates and hub are going to be a conversion? Am I reading it right?
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 03-16-2009, 09:23 PM   #1164
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
For anyone who can understand Japanese, id there a way to order just the brace and spring retainers?
Old 03-19-2009, 03:46 PM   #1165
Canuck's Avatar
Here's what I found when running this past weekend.
I used a 13.5 with 1S SMC + TQ Booster + 42T/72T gearing + Rear tire size 46mm (Rollout 84mm) + 8 minute main.
Pack had 33% capacity left in it at the end of the 8 minutes.
My Novak 13.5 was only at 110F and my fastest lap was 6.23 sec.
Question:
When I tried my 17.5 and played with the gearing/rollout I was never able to get it over 95F. And now with the 13.5 I am at 110F. Is this because of the lower voltage in the 1S lipo ? Trying to reach 160F seems impossible like the others with 4 cell NIMH packs.
Old 03-19-2009, 03:53 PM   #1166
chris moore's Avatar
Trader Rating: 87 (99%+)
Question:
How were you pace wise with the 4cell nimh cars with 13.5? 17.5? If your on pace at those temps then you have nothing to worry about. Remember that your carrying alot less weight around the track so temps could/should be lower depending on the track layout and driving style.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-19-2009, 04:00 PM   #1167
Trips's Avatar
Question:
Don't gear for a target temperature, gear for lap times. When the lap times stop getting better, stop adding teeth. ONly look at the temperature to know you're not overheating.
My 4 cell 17.5 car when geared for best lap times was coming off the track at around 140, my 3.7/13.5 comes off around 112 or so.
MARSHAL!!
Old 03-19-2009, 04:03 PM   #1168
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
check it
http://www.rctech.net/forum/r-c-item...2r5-fresh.html
chewiefttc4 is offline   Reply With Quote
Old 03-19-2009, 04:14 PM   #1169
Canuck's Avatar
I was a tad shy from a 4 cell driver but he was a good driver also ! So I guess I was geaered OK.
With my 17.5 I played around a lot with the gearing and the temp did not change much so I guess I will have to keep a better eye on the lap times ....
Old 03-19-2009, 04:52 PM   #1170
Canuck's Avatar
I would like to know what would be the best rear axle / hub / diff setup or aftermarket part for the 12R5 ?
Any suggestions ?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
