Old 03-04-2009, 02:38 PM   #1141
chris moore's Avatar
Trader Rating: 85 (99%+)
Originally Posted by Canuck View Post
Thanks for the info guys.
So 13.5 with LIPO 1S is equivalent to 17.5 with NIMH. Good heads up ! I need to get more info from other lipo users on this so we can put forward some kind of rules at the track.
Also look forward in receiving some gearing info and roll out.
Here's what I am thinking:
17.5 BL use 76T spur + 39T pinion to start off with 46.5mm tires. I get 75mm rollout
13.5 BL use 76T spur + 34T pinion to start off with 46.5mm tires. I get 65mm rollout
Check temp for around 150F on motor and adjust gearing.
From what I've read the 1s lipo with 17.5 is slower and the 13.5 is faster than 17.5/nimh, there is no direct equivilent. I just got the SMC lipo to try myself but I think your going to need more gear, on our med track I'm running 76/52-54 and I've been told I'll need a rollout over 90mm for the 1s/17.5
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-04-2009, 03:20 PM   #1142
Canuck's Avatar
Trader Rating: 25 (100%+)
So a small track would be less of a rollout for 1S/17.5 ? Something like maybe 80MM and 42 pinion / 76 spur ?
Wonder if anyone has experience with a 13.5 / 1S setup in a small track. Looking for rollout ?
Canuck is offline   Reply With Quote
Old 03-04-2009, 04:27 PM   #1143
Here is a quote from EddieM on the rollout for 1s. I dont know how big the track he is running on is but what is clear is that 1s rollouts are huge.
"17.5 drivers are running 100~110mm rollout and 13.5 around 88~96mm."
Sponsered by:
Old 03-04-2009, 04:38 PM   #1144
Canuck's Avatar
Oh my God ! That's huge gearing. I think I will be better off just to stick with conventional 4 cell NIMH and a 13.5T brushless motor.
So what would be the rollout in MM for this setup on a small track ?
Old 03-05-2009, 11:30 AM   #1145
RC MARKET's Avatar
or choice 2 cell Li-Fe 6.6V !
RC MARKET is offline   Reply With Quote
Old 03-05-2009, 12:20 PM   #1146
The rollout that you're going to need for 12th is going to vary a lot depending on what speedo you're running.
With a tekin RS at full boost timing I'm around 78mm in 13.5 on a fairly large track. Anything more than that just won't pull on the infield with my set-up.
Fred_B is offline   Reply With Quote
Old 03-05-2009, 04:05 PM   #1147
Totally agree, I have two sets of these and love them. Just as lightweight as the SMC lipo but t-bar freindly.
I've read that guys runing tekin with the 189 software have been able to drop up to 6 teeth and run the same lap times, so your right going forward the esc will play an ever more important role in rollout.
Sponsered by:
Old 03-06-2009, 02:09 PM   #1148
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Blackstock has posted his Mod and 10.5 set-ups from Snowbirds on the AE site if anyone is interested. Theres a 10R5 one in there too . . .
Old 03-11-2009, 05:12 PM   #1149
Canuck's Avatar
What size wire gauge you guys using on the 12R5 . I will be running 1S lipo + 17.5 Brusless.
Old 03-11-2009, 05:41 PM   #1150
OD Purple 16ga
Sponsered by:
Old 03-11-2009, 06:19 PM   #1151
Canuck's Avatar
Great thanks
Old 03-13-2009, 01:42 PM   #1152
Canuck's Avatar
Here's a quick question maybe the Oval guys can help me out ?
I want to use a Novak GTB 4-Cell Competition Brushed/Brushless Electronic Speed Control with my 12R5 1/12 pan car.
Will it work with the SMC 1S lipo and TQ booster ? Do I disable anything for the lipo cutoff because it is 1 cell ?
How about wiring , anything special with this hookup ?
Steve
Old 03-14-2009, 06:11 AM   #1153
Canuck's Avatar
If I cut my rear tires to start off at 46.5 mm at what size should I cut my front tires ?
Old 03-14-2009, 07:44 AM   #1154
Uga
Uga's Avatar
42-42.5mm should do for the beginning. You should go to your track and ask the fast guys what tire sizes are they using for your track to get more precise details
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 03-14-2009, 07:58 AM   #1155
theisgroup's Avatar
as most will tell you 46.5 is quite large for a rear tire. But i will start mine at that size for club races. usually the fronts I like them to be 2mm smaller. it seam that any less stager and the car pushes. I would go to a larger stager to add steering, but not much more then 2.5mm.
also if you tend to hit boards, you might want to cut them a little smaller. like say 42 front and 44 rear. just to help reduce chuncking. large tires are easy to chunk.
one more helpful advice is to glue the bead on the tires. expecially the yellow. they tend to chunk quite easily. I have chuncked yellow with no board hits. so I try to ca the bead almost every run just to reduce the chunking.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
