Old 02-22-2009, 10:13 PM   #1111
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Andew, I am using the Kimbrough Servo Saver Mid-Size w/Holes. HERE is Tower Hobbies Link to it: http://www3.towerhobbies.com/cgi-bin...&I=LXND49&P=ML
CarlosG. is offline   Reply With Quote
Old 02-22-2009, 10:51 PM   #1112
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Interesting, thats the same one Dumas has in his Rev5 right now. He said he felt the smaller ones did hold center well enough for him, especially in mod and 10.5. I will try one on and see if there's any difference. Thanks Carlos
Old 02-23-2009, 02:44 AM   #1113
OK, I tried the Kimbrough 201 and its no better than the smaller version. The offset from the splines to the flange where the studs mount is the same.
Heres a pic explaining where the problem lies. In this pic you can see the driver has moved the servo saver forward to allow the stud/ball cup to clear the servo. Anyone else running a Futaba 9650 on carpet with a 12r5 find a solution? other than cutting the ballstud and cup down?
Old 02-23-2009, 02:57 AM   #1114
Trips's Avatar
Trader Rating: 16 (100%+)
I'm not seeing the picture...
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-23-2009, 05:07 AM   #1115
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by andrewdoherty View Post
I am using a Kimbrough small SS and have the studs mounted in the middle hole. They are near perfectly parallel when viewed from vertical and horizontal perspectives. In the pics above you can almost see what I am talking about in the pics from above the car.
What hole are y'all mounting the studs in, and what servo saver?
Same as you . Nothing colliding here.... 12th scale right ?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-23-2009, 05:41 AM   #1116
http://www.overrc.com/courses/course...8/IMG_7817.jpg
oops!
LOL, ya, 12th scale.
Kimbrough small, middle holes. futaba 9650.
Old 02-23-2009, 05:41 AM   #1117
Ill try to get a pic of my car up later today . . .
Old 02-23-2009, 06:17 AM   #1118
CarlosG.'s Avatar
Andrew, by the time the ball cups hit the servo on my car, it is at full turn and rubbing on the ball cups on the links. I use this one cause it is more sturdy than the grey one mostly used for Futaba.
Old 02-23-2009, 06:55 AM   #1119
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
OK, I do love this hobby, but I am looking at timestamps and I am either needing glasses or needing less sleep to keep up. Andrew!!! It appears you went to the track between 00:51 and 04:44 to figure this problem out or took your car home. Get some sleep! Did the idea we discussed not work?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-23-2009, 08:22 AM   #1120
I bruoght all my stuff home this week. The idea we talked about caused the turnbuckles to rub on the arms; too much ackerman and no way to move the servo any farther back. I'll keep working on it. Obviously I'm doing something wrong.
Carlos, are you in the upper holes in the Kimbrough 201 med SS? I couldn't get the ball cups snapped on in the lower set of holes, but I didn't like how much bumpsteer there was in the upper holes. . .
Old 02-23-2009, 08:36 AM   #1121
LOL// omg just take out a few shims . Cut your tires down and get the ride hight correct ..Once you have smaller tires , the turnbuckles wont hit any more .
Old 02-23-2009, 09:05 AM   #1122
CarlosG.'s Avatar
I am using the top holes. You might want to shim the outside balls with a 1 mm shim to take out some bumpsteer.
Old 02-23-2009, 04:23 PM   #1123
Something is very odd indeed. I have faith in you finding a solution!
Brian, sshhhh!
V-Dezign 4.0
Old 02-23-2009, 08:40 PM   #1124
Ffejdat's Avatar
John St.Amant or anyone else- didi you ever come up with a solution, or a fix from assoc or yourself for the uneven front caster problem? Just wondering what the fix was, or which part was bad, remedy, etc... Haven't seen it here yet, but good to know what the fix is if it pops up... THANKS!!
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 02-24-2009, 05:31 AM   #1125
My parts came today and I have to do some parts swapping . Not very sure yet what the issue was but its most likely one of the 3 plasticks in the front end .. DUH! lol It might be a while b4 I know for sure. I haveto do a lot of A/B comparrison b4 I have a good idea whats causing it. I had thought it was the lowers . But that remains to be seen. More later...
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
