Old 02-17-2009, 02:40 PM   #1081
Ffejdat's Avatar
For the people having such a large difference in caster left to right; Please take few minutes and try to isolate where the problem is coming from, or which part is at fault, here is what I would do.
First, mark every part in the front end on ONE side, left, with a small piece of tape or something, then start swapping parts left to right and see if the problem moves to the other side of the car. start with the upper arms, pull the pins and just swap, then do the upper arm mounts, etc. etc. till you find the problem, you will NOT have to pop the pivot balls out and turn them around, just leave them upside down on the other side for now and you should still be able to see if the caster changed or not, it should take maybe 10 minutes of fiddling with the front end to figure out where the problem is, just 2 wrenches and a few minutes should isolate the problem. Just dry fitting the kingpin in the upper and lower arm, and steering block, no e-clips, spacers, or spring, should be good to see where the problem is.
My money is on an upper arm assembled crooked, or board hit crooked, or on one of the blue standoffs being off to the other one.
On the lower arms, it helps to deburr or de lip the flash on the end of the arm, the area that butts up against the standoff, before bolting down, just be carefull you don't create an angle or bevel there, cause the arm will not bolt down straight then, will point up or down slightly.
we have about 6 to 8 12r5 cars running in our area, have yet to see this problem, guess we are lucky....
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 02-17-2009, 03:08 PM   #1082
AE-Reedy
Originally Posted by YmeBP View Post
I've recently gotten a 12r5 and i'm having trouble w/ the car hooking to one side and pushing to the other, i've check tweak, and wheel centering. I run brushless and try to balance the weight between the left and right electronics wise.
Any ideas on where to start looking (oh and i checked all my bearings and rebuilt the diff too).
First start with the basics.
1. Make sure that the radio end-points are even left and right. Double check by turning circles on the floor and adjust as necessary until the car turns the same amount left and right.
2. If that doesn't help then verify that the rear links move freely. Be sure that the rear pod alignment is good and not causing any binding. It might be necessary to loosen the screws that hold the center pod pivot and re-adjust the linkage alignment. That step is not explained very well in the manual. It is best to do this with the pod plates removed so you are just dealing with the lower graphite plate. When you rock the plate side to side the action should be smooth and free, you shouldn't feel any binding or popping.
Reassemble the car re-check your tweek and see if this has helped.
What method are you using to set tweek?
Sean Cochran is offline   Reply With Quote
Old 02-17-2009, 10:01 PM   #1083
Originally Posted by John St.Amant View Post
I didn't throw my transmitter.... you are greatly mistaken. I put it on the table quite abruptly! I still use the same one. And as for the pot calling the kettle black.... Who yelled a profanity from the drivers stand. That was a blaitant violation of ROAR rules and no one said a thing! I have a God given right to express my opinion and these forums are here for just that reason. I answer to no one and for as much stuff as I have bought and had to send back. I've had to ship just about everything (or atleast one of) back to whomever and it all adds up. Seems to me that when I give an oppritunity to enlighten someone about something , it's all taken out of text and read between the lines . So I talk in conjecture and apparently there is a lack of reader intelect involved. I must have spent over $100 on shipping for motors , speedos, parts, odds and ends for warranty witch should have never been an issue in the first place . It's idocracy and lazieness. passing faulty "new" stuff to consumers just to make a few bucks and get product on the shelves. I'm not sponsored by FedEx man. So.... peanut butter was an example. Open your eyes man. All I was doing was making an accure observation and notifying everyone in a manner that which many have access to. So as far as everyone getting all defensive <shut up> !
Is Associated willing to replace everyones faulty parts? I wonder, maybe they will. So if thats the case I too would encourage everyone with one of these pan cars to persue non-faulty parts from customer service. Things like this are cause for extra effort.... extra carbon emmissions.. extra bull crap.. more typing .. more backlash. Is it all neccessary ? No.... ITS MANDITORY!
The squeaky wheel gets the grease! perhaps I should spell that out for you as well. Not you Jeremy....
John you have a PM.
Jeremy Otis is offline   Reply With Quote
Old 02-18-2009, 01:36 AM   #1084
Robert_K's Avatar
This is a good advise, and when your done with that I would recomend checking or replacing your front springs. I've noticed that the 0.20's from Asso collapse a bit fast when hitting a cerb, just a bit to hard... ;-)
I replace them frequently. Good luck!
Greetings,
Robert Krens
Team Associated Holland
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 02-18-2009, 04:43 AM   #1085
PartTime's Avatar
And there is your problem. I did that and had tweak from hell. Take the motor out and balance the chassis. Drop the motor back in, reset tweak and drive. Your hook should go away.
DK
PartTime is offline   Reply With Quote
Old 02-18-2009, 09:43 AM   #1086
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Look at your king pins . Most likely you have an issue with caster ..Like most of us do. Call Associated.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 02-18-2009, 11:50 AM   #1087
YmeBP's Avatar
Trader Rating: 32 (100%+)
Thanks for the reply, i was supposed to post pix last night but got in from work late .
I've done the endpoints, i've run the circles on the floor, i've checked rear pod links for movement and just in case length and damage, i've checked side springs for damage (just in case one is longer than the other), i've also checked that my motor wires aren't binding (too short or too long) so that the pod isn't binding up. I took the shock off and checked for free movement all around.
DK
I will definately try this, i've heard rumors that there is a centered pod for brushless floating around as well.
I'll have to double check the front springs.
I have also promised another poster that i'd take photos. I'll do that this evening by hook or by crook and post them .
Thanks again all for the quick replies and the info!!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 02-18-2009, 01:23 PM   #1088
chris moore's Avatar
Trader Rating: 85 (99%+)
One more thing to check is that your rear axle is centered, if not that can cause this issue as well.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 02-18-2009, 05:20 PM   #1089
Trips's Avatar
Trader Rating: 16 (100%+)
ymebp,
one other thing to check, if you'/re running a Parma Speed8 body, look for interference from the upper pod plate on its right side where the side shock attaches. Mine hit the body right there. It only happened with the Parma Speed8. That can cause incosistent handling left and right, even if the car is teaked properly.
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-18-2009, 08:03 PM   #1090
YmeBP's Avatar
Yaaay i've got mail! ... yaaaaay i've got mail ... yaaay
http://www.skyersfamily.com/gallery/...ars/?g2_page=2
higher resolution images at the link above.
Old 02-18-2009, 08:54 PM   #1091
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default pic of my wireing
hey here is the way i did my electronics the zip ties i used are very loose so all wires can move very easy hope that helps ya , how old are your tires
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 02-18-2009, 09:07 PM   #1092
wingracer's Avatar
Trader Rating: 22 (100%+)
It's hard to tell from photos but it could be the caster problem. It looks like one side is straight up but that could just be the camera angle.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-18-2009, 09:19 PM   #1093
YmeBP's Avatar
You have a point, lemme see if i can get a better looksee. Took the wheels off and to the naked eye it looks like one side has more caster than the other. I have 1 number #4 washer under each screw in the front end blocks.
Old 02-19-2009, 04:56 AM   #1094
PartTime's Avatar
the speedo is on the same side of the chassis as the servo. its out of balance. Same mistake i made.
HTH
DK
Old 02-19-2009, 06:40 AM   #1095
Personally I would have the speedo on the left also. It does balance the chassis better there. It's probably only part of the problem though.
So, the first thing I would check is the axle heights. Double check that the camber is the same on both sides and pull the tires off. With the chassis flat on a set-up board measure the axle height on both sides with calipers or a sedan droop gage. The axles should be the same height within about .25mm and if they're not try loosening the screws on the lower arms and giving them a little jiggle before retightening. I've had the lowers get a little off after hitting a wall or from just getting assembled a little funny. If you can't get the axles correct try new screws in the lowers and you might need to replace them all together.
Second thing is to check the caster. Just use a camber gage at the front to measure how the kingpin leans back. Again, wheels off, chassis flat on the board and make shure that the upper pivot sets flat on the gage. I try to keep the caster within a half degree for both sides. Contrary to some of the agruments on here it's not that hard to reshim the upper arm to get them the same. If you need a little more room to move just dremel a little off the block to make room and add a shim. It's not a big deal.
Also, check the springs. A factory driver told me to set-up new springs like this. Compress the new springs some with your fingers (just enough to gently bottom them out). Put them on the car and shim them at the spring end to take out play or add one shim of preload if you're running 18's. Run the car once or twice and recheck the springs for proper shims (no preload for 20's and one shim for 18's). If one of the springs collapses from where you set them (crash) you'll need to start this process over again.
Fred_B is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
