Old 01-01-2009, 11:31 AM   #901
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
other people dont even know what the dave point is..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-01-2009, 01:17 PM   #902
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
LOL... i jumped the gun yes .. But you defined roll center and then said it wasnt roll center. Thats why you got the coment.
John St.Amant is offline   Reply With Quote
Old 01-01-2009, 02:06 PM   #903
Originally Posted by tim fry View Post
Hi all
Has anyone had an issue with their bodyshell rubbing the top corner of the motor pod where the side shock mounts? We mainly have to use the Parma Zytek or Hotbodies Reynard in the UK and even with the shell mounted level with the top of the chassis the corner of the motor pod touches at certain angles.
I tried to heat up a spoon to make a bubble in the shell but it went very wrong.
Any ideas please?
We pretty much just let it hit. Allowing the body to fit loose on the mounts will keep it from doing anything too bad. By loose I mean run the body clips a little above the body so that it can move up and down as needed.
John, Ackerman isn't that hard. Haven't drawn it out in years because we use it as a tuning aid in 12th. That's what the spacers on the servo mount are for.
Fred_B is offline   Reply With Quote
Old 01-01-2009, 02:14 PM   #904
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
New to 1/12 im setting up my car to run 13.5 what is a good pinion to
start with ?? it currently has a 96T spur on the car. Cant wait to throw this thing down on the track.
FS-Samsung-galaxy-tab-3g-verizon
**PLEASE CHECK MY OTHER ADDS LOTS FOR SALE**
Garage: ITS ALL FOR SALE LOADED Tamiya M03R,LOADED AE TC5R (VTA), LOADED Duratrax Vendetta ST
IL_AudiRacer is offline   Reply With Quote
Old 01-01-2009, 05:45 PM   #905
ben73's Avatar
Trader Rating: 40 (100%+)
I am going to buy my 12R5 today and would like to know which servo fits in directly and any recommendations you all have. I am currently looking at a futaba S9650 mini servo
ben73 is offline   Reply With Quote
Old 01-01-2009, 05:54 PM   #906
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
9650 fits perfect.
Old 01-01-2009, 06:27 PM   #907
TimNJ's Avatar
Trader Rating: 50 (100%+)
Welcome to 1/12! You might want to get rid of the 96T spur and get 80T and 84T PRS spurs for starters. Depending on which brand of 13.5, track size and other factors, start with a conservative rollout in the low 60's (mm), temp the motor and gear from there.
Trinity - Caster Racing USA - Panther Racing
Race Videos: http://www.youtube.com/TrackMasterTim
TimNJ is offline   Reply With Quote
Old 01-01-2009, 06:29 PM   #908
To be honest many of us are running 88 at the largest for the spur with a 13.5 With anything bigger it can get pretty hard to fit a big enough pinion on the car with smallish tires.
Old 01-01-2009, 06:44 PM   #909
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default mail
Fred-B you have mail
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 01-01-2009, 08:22 PM   #910
Thanks fred whats a good pinion for an 88T spur just looking to turn some laps and get used to the car fairly large track.
Old 01-01-2009, 08:29 PM   #911
Marcus, do yourself a big favor and get an 84T spur, then you can use a range of pinions of 42 to 46 to maintain a 68-70mm rollout. An 88 will limit you and cause you to replace tires more frequently as they get smaller in diameter.
I'm using the 84 in my R5 with a 13.5 at the rollout mentioned and it works well. Made the A Main today at Jtec.
If you have new tires that are 46mm in diameter and want to use an 88 try a 41T pinion to get a 68mm rollout or a 43T pinion for a 70mm rollout.
AreCee is offline   Reply With Quote
Old 01-01-2009, 11:25 PM   #912
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Man sounds like I missed out on a good day to be at jtec. Owell see you sunday. Made some more small changes tryin to fine tune and get used to drivin again..lol
Have any of you tried different weight oil in the side damp shock? Other than 20wt? Sean, mike anyone?
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 01-02-2009, 12:15 AM   #913
t4m1y4niac's Avatar
guys, where can i get an articles about ROLL OUT...
thx.
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 01-02-2009, 12:48 AM   #914
roadkill's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to roadkill
hello, I have a 12r5 issue, my rear pod seems to be anything but flat.
first of I have new upper and lower pod plates, new right and left axel plates,and a new football.
the problem is that when I put the motor plates on the bottom pod plate,my bottom pod plate becomes warpred, I hold down the 3 points that attach to the car,and the back of the pod lifts up,so i take the pod apart and all the parts are flat.but when i put them together, the pod seems warped, any body else have or heard of this problem?
Keeper of the check book, Pit butler,(for hire) President and life long member of the Black Flag Club,
roadkill is offline   Reply With Quote
Old 01-02-2009, 05:52 AM   #915
Hi,
are your motor plates the same height? Perhaps they tweak the pod plates...
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
