Old 12-30-2008, 08:50 PM   #871
P2
P2's Avatar
Trader Rating: 15 (100%+)
It makes the upper arm longer which smooths out the steering a bit. With the longer upper arm there is also less camber gain. This little trick is just a tuning option
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-30-2008, 08:53 PM   #872
mkdut's Avatar
Trader Rating: 19 (100%+)
Might have to give it a try. No issues with the strength of the front end?
mkdut is offline   Reply With Quote
Old 12-30-2008, 09:20 PM   #873
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
It will not affect the car on asphalt but will need a brace for carpet. It's a great tuning option.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 12-30-2008, 09:39 PM   #874
mkdut's Avatar
I'm guessing too much lateral force(grip) on carpet where on asphalt becuase of the reduced grip it's not an issue. I guess I'll have to wait a few months before I give it a try on asphalt. Thanks again for the info.
Old 12-31-2008, 01:40 AM   #875
Trips's Avatar
Trader Rating: 16 (100%+)
Is it just me, or does the servo saver look like a panda bear face from that angle?
I know... but it's late here.
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-31-2008, 01:56 AM   #876
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Yes,it does!
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 12-31-2008, 08:10 AM   #877
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Umm,,, I think he just raised the roll center.
John St.Amant is offline   Reply With Quote
Old 12-31-2008, 08:42 AM   #878
There was a rear bite issue at the worlds this year. The 1/12th scale cars just could not get enough rear traction. If you go back and look at any of the pictures from the 1/12th worlds, you will see that every car had a Gurney lip on the back of the body in an attempt to get more rear bite. When was the last time you saw anyone running a Gurney lip on a 1/12th car at any big event? One of the ways you can get more rear bite, or balance, is to decrease front bite. By lengthening the upper A arm, you decrease the camber gain through the movement of the suspension making for less aggressive front bite. It does not change the front roll center. Only changing the angle of the upper A arm in relation to the lower A arm or surface of the chassis, changes the roll center.
Also keep in mind that at the worlds, the Associated team was the only team with access to Masami's secret tire foam. It was probably the same foam that Masami used to win the worlds in Florida a few years back. I also saw pictures of other teams from the first days of the worlds that where mounting foam in an attempt to find that elusive rear traction. Have not seen that happen in a long time!! I even saw a picture of Andy Moore mounting foam on wheels.
Crashby is offline   Reply With Quote
Old 12-31-2008, 10:02 AM   #879
Your an idiot...
Old 12-31-2008, 10:38 AM   #880
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
on the contrary my friend, on asphalt they are looking for the most total grip. so taking grip away from the front only lowers your corner speed. but if you add rear downforce while maintaining the same front grip that nets you more low speed steering with more total high speed grip...
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-31-2008, 10:39 AM   #881
rx7ttlm's Avatar
Originally Posted by John St.Amant View Post
Your an idiot...
Who are you to be casting stones....
Old 12-31-2008, 10:40 AM   #882
P2
P2's Avatar
Yeah Crashby...you're an ID10T. You've only been doing this for 20+ years I agree with you though
Old 12-31-2008, 10:55 AM   #883
Not to fret, P2. Opinions are like a**holes, everyone has one. But sometimes they become one.
Old 12-31-2008, 10:57 AM   #884
Just sent you a PM.
Old 12-31-2008, 11:41 AM   #885
I've been doing this for almost 30 years now and changing the ratio of the length or the upper arm and lower arms including the angle of the upper arm effects the ROLL CENTER. What ever effect you may have described is in fact a ROLL CENTER change. Raising the roll center make the wheel camber gain and lowering it does the opposite. And I AM John St.Amant thank you.
I may resemble your remark, but concidering the source....
remember some values are absolute and usually refered to as positive when it is actually and commonly not refered as a negative value.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
