Old 12-26-2008, 12:28 PM   #856
nashrcracer's Avatar
R/C Tech Charter Subscriber
I thought it was a car width issue. the stock pod with certain rims made the car over the 172mm roar rules and not able to run at most major events. not a problem with club racing unless you have a track tech nazi.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-26-2008, 02:55 PM   #857
mkdut's Avatar
Trader Rating: 19 (100%+)
With the brushless pod without the new hub the rear width is about 173mm running Jaco Prisms. With an IRS hub the rear width is about 172.5mm.
mkdut is offline   Reply With Quote
Old 12-26-2008, 02:57 PM   #858
Trader Rating: 23 (100%+)
So basically, anyone going to the Nat's will need the new parts to be legal width?
SteveL is offline   Reply With Quote
Old 12-26-2008, 04:19 PM   #859
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
My car with stock parts, wheels centered, jaco prism wheels is about 170-171, so you shouldn't need the new parts.
brians11 is offline   Reply With Quote
Old 12-26-2008, 04:44 PM   #860
P2
P2's Avatar
Trader Rating: 15 (100%+)
Brian, I think they were talking about the brushless pod w/out the BL hub...and using the stock or IRS hub.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-30-2008, 08:56 AM   #861
Unhappy
12R5 She needs to go on a serious diet! Any word on aluminum screw kit? I would also like some slight weight front blocks to replace the aluminum ones.
Brad Mergy is offline   Reply With Quote
Old 12-30-2008, 09:17 AM   #862
P2
P2's Avatar
You can get blue aluminum screws at http://www.fastener-express.com/inde...S&Category=218 and they match the Associated blue
Old 12-30-2008, 09:41 AM   #863
mkdut's Avatar
I typically get all my screws from these guys. The best selection of aluminum metric screws in several colors and quick shipping.
Old 12-30-2008, 10:17 AM   #864
Thanks for the link to the aluminum screws! I couldn't find M3 X 5 mm so I guess I will have to just shorten a longer lenght screw.
Old 12-30-2008, 10:24 AM   #865
racer x 1's Avatar
Trader Rating: 27 (100%+)
hey does anyone have a good outdoor asphalt set-up running a 10.5 motor.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-30-2008, 10:43 AM   #866
mkdut's Avatar
I used the 3x6mm screws on all location that called for a 3x5 with no issues.
Old 12-30-2008, 10:51 AM   #867
M3 X 6 excellent that makes life a lot easier!
Thanks!
Old 12-30-2008, 03:10 PM   #868
P2
P2's Avatar
Start with the kit setup and make these small changes:
25wt in center shock - Gold spring
20wt in rear shock - Green springs
Shock mounted 3rd hole down in front
172mm rear
Turnbuckles form straight line when viewed from above
Turnbuckles slightly higher at steering block, shim up .5-1mm
Battery rear
Pink rear tires - Sauce full rear
Double Pink fronts - Sauce 1/2 front
3.75mm ride height front or 4mm if too much steering
4.00mm ride height rear
Droop in rear pod, 1mm up.
.5* toe out up front
Parma Speed 8 body, if you like more downforce use Speed 12
This is for med bite asphault.
Old 12-30-2008, 03:52 PM   #869
Trader Rating: 16 (94%+)
Holy Cow - Those are awesome prices for Aluminum Screws. Now I know just how badly us consumers are getting screwed by those kit costs.
KSN
kn7671 is offline   Reply With Quote
Old 12-30-2008, 08:33 PM   #870
mkdut's Avatar
So I happened to be going back thru this thread earlier today and noticed something on Matsukura's car from the Worlds that I hadn't noticed before. If you look at the pic you can see that he is running spacers between the upper arm mounts and the bulkhead and not running the hinge pin brace.
What is the advantage/disadvantage to doing this?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
