Old 12-08-2008, 04:32 PM   #826
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
The tape is it for now. I hanent seen anyone try and fab a mount yet for it.
On the brushless side of things all the guys here are going back to the old 19turn brushed motors. Seems to be faster than the 13.5 brushless.
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 12-08-2008, 05:54 PM   #827
TimNJ's Avatar
Trader Rating: 50 (100%+)
For anyone who might have been following my posts from a page or two ago, my R5 was absolutely dialed on Sat. night.
Instead of it getting looser and looser as the rounds went on, as it had done in my first couple of racedays with the car, it actually started out a tick loose in the first qual and tightened up and came in perfectly as the rounds went by and the groove got established. Infact, I set the track record with 80 laps in 8:03 in the A-main (smallish track and we're running 17.5/27T) I think my good runs on Sat. were a combination of having a good setup and just figuring out what the car likes and doesn't like asfar as driving technique goes.
I was geared 76/46 with a Trinity Duo 17.5 on 44.5mm Jaco Prism gray rears & lilac fronts. I'll have video of the heats and A-main as well as my TC heats and main on my Youtube page in the coming days. I'll post again with the link as soon as they're uploaded.
As for the 9650 servo, I kept the side mounts on my 9650 and direct-mounted it to the chassis. The servo horn is perfectly centered and it works great.
Re: Brushless pod. I bought the top and bottom plates a while ago, but no one seems to ever have the hub and thrust cone in stock. I guess I'll have to B/O it. In the meantime, I've had good success running my Duo 17.5 with the standard pod. Like another poster said, the car tracks straight and drives fine. I still want to try the B/L pod, though, just to see if I can notice any difference.
Trinity - Caster Racing USA - Panther Racing
Race Videos: http://www.youtube.com/TrackMasterTim
TimNJ is offline   Reply With Quote
Old 12-08-2008, 05:54 PM   #828
CCH1978's Avatar
Trader Rating: 27 (100%+)
thanks for the info
MINI REVO Mamba Max Pro NEU POWERED
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES
BEAST MODE (ON) OFF
CCH1978 is offline   Reply With Quote
Old 12-08-2008, 06:27 PM   #829
Ffejdat's Avatar
Timnj- there are a few of those hubs on Ebay stores, sorry, no links...
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 12-08-2008, 07:06 PM   #830
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default conversion
does anybody have part numbers to convert the stock car to brushless lmk thanks
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 12-08-2008, 07:30 PM   #831
Originally Posted by Sean Cochran View Post
These are the parts you need to make the "brushless" pod.
8511 -10R5 lower plate
8512 -10R5 upper plate
4608 -12R5 diff hub narrow
4609 -12R5 thrust cone
The motor plate is repositioned on the graphite pieces to change the weight balance of the pod. The hub and cone are needed to keep the rear width legal.
here ya go..
Old 12-08-2008, 08:23 PM   #832
2056dennis's Avatar
Default parts
here ya go..
thanks for info and does anybody know where i can get the hub thats all im down to thanks
Old 12-09-2008, 03:44 PM   #833
fire929's Avatar
Default ?????
Can anyone help me understand what is meant by 25,000 or 60,000 wt kingpin lube. And what it changes. is the front vertical shaft that has the little front springs
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 12-09-2008, 04:06 PM   #834
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
the front end of a pan car isn't engineered with a damper, so you glob on some high viscosity silicone lube that dampens the movement..
cheers
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-09-2008, 04:47 PM   #835
2056dennis's Avatar
Default brushless hub
so does anybody out there know if the crc narrow hub is same as the ae brushless hub
Old 12-09-2008, 05:55 PM   #836
Trader Rating: 7 (89%+)
yes, all that you need the hub to do is be shorter by 3mm.
Johnny Carey is offline   Reply With Quote
Old 12-09-2008, 07:06 PM   #837
P2
P2's Avatar
Trader Rating: 15 (100%+)
A temporary alternative to the brushless hub is to use an IRS hub w/jaco tires. This combo is 86mm from the center line w/out any spacers. Your car will be at the max 172mm limit and you won't be able to fine tune the rear track. I ran this combo for a short period until my brushless hub came in....just a thought
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-09-2008, 07:53 PM   #838
2056dennis's Avatar
thanks p2 but im going to do the crc deal like Jonny Carey said i can get it in blue also i think , does anybody know how to get intouch with Mark or Frank they dont have there number on there site to contact them
Old 12-09-2008, 09:48 PM   #839
It works, just make sure axle is centered.
Team CRC - (315) 338-0867
Old 12-10-2008, 10:23 AM   #840
TimNJ's Avatar
I just ordered my hub and thrustcone from Stormer. As of a minute or so ago, there are 3 hubs left and 5 cones left. Get 'em while they're hot!
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
