Old 12-07-2008, 11:04 AM   #811
I've finally made the decision that I'm going to go Brushless and I have a quick question.
Is it absolutely necessary to go with the re-balanced pod on the 12R5?
Will the cars handling be all out of whack if I try to run a brushless motor in the stock rear pod?
Thanks in advance!
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 12-07-2008, 12:14 PM   #812
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Well.... I for one am waiting for the centered brushless parts.
But , why not try it and do an a-b comparrison and let us know.
I don't have any more brushed motors to try it.
But I would imaging a slight advantage to centering up the motor.
John St.Amant is offline   Reply With Quote
Old 12-07-2008, 12:22 PM   #813
Hi i run a 10.5 brushless in the standard pod and cant say I have noticed any problems, still tracks true and straight. Did my best to balance the parts out on the chassis to try and even tyre weights up and it seems to work well.
Might try the brushless pod one day when I see one at the local shop but happy with it so far.
Need to sort out my lack of rear end after 6 minutes before changing anything else!
fludey is offline   Reply With Quote
Old 12-07-2008, 12:35 PM   #814
Hi guys,
regarding the new pod I have to say there is a difference but it doesn't make the car faster, just more consistent. I tried it back to back and for me the car feels "straighter" with the new pod. But lots of the R5 drivers here drive the normal pod as long as it is not available and have great success with it.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 12-07-2008, 01:47 PM   #815
P2
P2's Avatar
Trader Rating: 15 (100%+)
I've run both and really didn't see any noticable difference. After spending the $50+ on the brushless pod and running it, I thought to myself.....hmmmm It doesn't make that much difference.
One thing it did do is balance the car out....on IRS balance buttons, the car is balanced.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-07-2008, 03:43 PM   #816
fire929's Avatar
Default Servos
Can anyone suggest a good servo i struck out with the mini's. Not wide enough
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 12-07-2008, 04:14 PM   #817
Rdog's Avatar
Trader Rating: 83 (100%+)
I have the Futaba 9650 in my car it seems to fit ok in my car.
Rdog is offline   Reply With Quote
Old 12-07-2008, 04:21 PM   #818
fire929's Avatar
Default Thanks
did you cut the two side mounts off? the non traditional mounts?
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 12-07-2008, 04:56 PM   #819
Rdog's Avatar
Yeah the ones on the top and the bottom? After that if fit perfect. Its a great servo picked it up at my LHS for around $50.00
Old 12-07-2008, 09:04 PM   #820
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I thought I'd share an idea.
Although its not really too big of a deal, I don't like having to get a 3mm and 2 mm wrench out when I want to remove my center shock to remove or install my batteries. So I devised a way to make the attachment tool-less.
Materials:
(1) 8 mm x 2 mm FH metric screw
(1) 2 mm knurled metric thumb nut
The yellow in the picture represents the thumbscrew. The magenta represents the FH screw. Rough up the bottom of the shoulder of the ball in the shock end. Insert the FH screw all the way into the ball and tighten them against each other. (I used a FH screw to allow the shock some articulation) Then use the thumb nut to secure the shock on the other side. The rough surface of the ball against the CF mount allows you to tighten the thumbscrew without having to use a wrench.
Old 12-07-2008, 09:30 PM   #821
The 9650 fits better in the 10R5. I found that the KO 949 is a much better fit for the car and is super smooth.
Old 12-07-2008, 10:55 PM   #822
Trader Rating: 8 (90%+)
Materials:
My battery always just slid right under the shock without taking it off.
Johnny Carey is offline   Reply With Quote
Old 12-07-2008, 11:10 PM   #823
That's pretty much what I was thinking I'd do! I just wanted to make sure that there wasn't some known, radical issue with running brushless with the original pod and it doesn't sound like there is so I will start with that and see where it leads
Cheers,
Mike
Mike
Old 12-08-2008, 12:09 PM   #824
I am looking for a brushless hub ASC 4608 does anyone know where one is available?
Thanks!
Brad Mergy is offline   Reply With Quote
Old 12-08-2008, 01:42 PM   #825
CCH1978's Avatar
Trader Rating: 27 (100%+)
I recently bought one of these cars and was wondering what options you have as far as holding the battery pack down besides tape
MINI REVO Mamba Max Pro NEU POWERED
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES
BEAST MODE (ON) OFF
CCH1978 is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
