Old 12-06-2008, 11:54 AM   #796
on our carpet track which is fairly low bite for carpet, grey rears work great for 6 minutes but get very loose at the end of the run. it's an easy fix just by going to pink rears. they don't seem to give up on the back end of a run like the greys do. when I go to places where the grip level is higher, the greys are a good choice. but at my home track, they just won't bite for the whole 8 minutes.
vafactor is offline   Reply With Quote
Old 12-06-2008, 12:31 PM   #797
Trader Rating: 45 (100%+)
The front tires are getting softer and gaining more grip after each round. You could put new fronts on each round and that would solve the problem.
You can also clean the front tires with motor spray after each round. Spray some motor spray on a paper towel\rag and wipe the gunk off the front tires and let the tires dry. You won't feel that tacky layer anymore after it dries. Or if you have a truer you can skim the fronts slightly each round to get the gunk off the tires.
Apex is offline   Reply With Quote
Old 12-06-2008, 02:40 PM   #798
Ike
Ike's Avatar
For those of you having issues later in the race with the front tires, I'd check into compounds... I noticed at least one of you mentioned purples and I'd say that's at least part of if not all of the problem. Try double pinks if you think a little more steering will be doable or lilacs if it's a high grip track. On my link cars I've usually liked yellow rears and either pink of lilac fronts unless there is insane grip then black fronts work. I gave up on purples a while ago...
Ike is offline   Reply With Quote
Old 12-06-2008, 02:48 PM   #799
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I used blacks with alot of success on high bite.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 12-06-2008, 04:40 PM   #800
Did my first run with a Tekin 13.5/RS today and right out of the box the car was spot on. All I needed to do was play with the tire sauce (and not chunk a rear tire ). The basic set up worked great with dbl pink front and magenta rear Jaco Prisms uncut on a low-medium bite track.
Great car, glad I chose it.
AreCee is offline   Reply With Quote
Old 12-06-2008, 05:31 PM   #801
fire929's Avatar
Default ?????
What kind of servo are you running on the 12R5?
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 12-06-2008, 05:57 PM   #802
Question...Does the R5 front end bolt onto a L4? Or are they just too different.
trf415ms is offline   Reply With Quote
Old 12-06-2008, 06:00 PM   #803
Trader Rating: 7 (89%+)
The R5 front end uses reg 3x8mm screws to attach it to the chassis while the L4 front end used 8-32 screws.
Johnny Carey is offline   Reply With Quote
Old 12-07-2008, 05:58 AM   #804
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
a rc12 with metric screws, i'm still tryin to digest that. that single cell lipo looks neat, saw 1 of those yesterday. i was fortunate that the shop didnt have a R5 in stock, cuz i prolly wouldve walked out with it.
R
well not 'walked out' with it, but paid for it 1st
UltegraSTI is offline   Reply With Quote
Old 12-07-2008, 08:02 AM   #805
Taz_S's Avatar
I still doing a that if they would have made it m4 screws with the same holes as there old front end. AE would have sold a ton of the new front ends to ever one that want to try the new front end. A 4m screws would have fid the 8/32 holes just fine.
I know i would have gotten 4 to 6 of the new AE front end if they did that.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 12-07-2008, 09:17 AM   #806
Ffejdat's Avatar
I think the aluminum standoff in the front end would have been way too thick and heavy to have a 4mm hole in it, a shame really as I and many other people would love the new front end on other cars...
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 12-07-2008, 09:38 AM   #807
xtrememadness's Avatar
Send a message via AIM to xtrememadness
or manufacturers could start putting the new front end in there kits. and they can make a chassis conversion for existing kits i like the adjustability of the new front end and it looks stronger.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-07-2008, 09:43 AM   #808
Taz_S's Avatar
Not to much, it would be a little more of work but they could have done it. It would have been a great drop in for the old front end. The 350 chevy block of pan car front ends.
Old 12-07-2008, 09:45 AM   #809
Taz_S's Avatar
It a good front end but when more then 90% of the car out there came with the bolt holes for the old and DS AE front end it hard to change that.
Old 12-07-2008, 10:29 AM   #810
TJames987's Avatar
Trader Rating: 9 (91%+)
how do you figure rollout or FDR for a 17.5 motor on the 12r5 car? Im guessing you just use the formula for the sedans without multiplying the internal ratio?
TJames987 is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
