Old 11-24-2008, 12:26 AM   #751
Rdog's Avatar
Trader Rating: 83 (100%+)
Originally Posted by mkdut View Post
Start at about 70 and work from there depending on your motor and track.
Mike the track would be sir and the motor would be 13.5
Rdog is offline   Reply With Quote
Old 11-24-2008, 06:25 AM   #752
mkdut's Avatar
Trader Rating: 19 (100%+)
By motor I actually meant brand. At Timezone I tried from 72 to 76 with a Novak. Others ran as high as an 82 with a Trinity. Get that thing together for Wednesday.
mkdut is offline   Reply With Quote
Old 11-24-2008, 07:04 AM   #753
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
LOL check the motor specs for k(rpm)/v and torque ratings.
Less rpm.... bigger pinion
Far as i can tell the Novak has more killa watt hours at 195 the trinity only 165. Not so sure how accurate my info is but ... thats the internet 4 u
John St.Amant is offline   Reply With Quote
Old 11-25-2008, 03:16 PM   #754
shipwama's Avatar
what is everyone using for oil in the top shock ?
im also finding that the inside rear tire will lift on a tight corner, should i strengthen the front springs?
shipwama is offline   Reply With Quote
Old 11-25-2008, 03:53 PM   #755
depends on the available traction .. I 'd prolly stiffen the side oil, front and rear springs as well. thinkin sliding would be better than liftin a tire . maybe less dope up front or shorter soaking interval. helps to know if you glued the sidewalls too. but id try one at a time , maybe side oil first.
Old 11-25-2008, 04:57 PM   #756
shipwama's Avatar
ok thank you, no glue on the sidewall, also rideheight was a little high, im going to lower it o a good height, then check it
Old 11-29-2008, 07:12 AM   #757
TimNJ's Avatar
Trader Rating: 50 (100%+)
Just a couple pics of my newly completed 12R5 and a few questions..
1. Caster: Does the 10* setting give more turn in than the 5* setting or vice-versa? I ask because I had bought a used CRC CK 3.2 a month ago and used 5* caster blocks and the car was just about perfect. Since the kit setting on the 12R5 is 10*, I had to ask.
2. Caster shims: Does the shim placement (1.80*, 3.25*, 6.15*) get subtracted from the caster number or added to it. For instance: If I'm running the 5* caster setting and the 3.25* shim set-up, do I now have 8.25* of total caster or 1.75* of total caster?
3. Does lowering the mounting position on the front of the center shock make the spring rate stiffer or softer?
Trinity - Caster Racing USA - Panther Racing
Race Videos: http://www.youtube.com/TrackMasterTim
TimNJ is offline   Reply With Quote
Old 11-29-2008, 07:47 AM   #758
OK... first thing is the radius of the upper arm is determining how much castor is taken out of the kingpin when it is loaed. For instance , what ever you start out with ( I'm running 6.25) that is the initial setting . When you go around the corner the suspension becomes under a loaded condition and the castor is then reduced . This gives the car more grip in the middle of the turn. If you were to change to the 5 degree setting for the upper arm, you would not have as much of this effect.
The spacers in the upper (thick and thin) are for setting the initial castor and that effects the amount of weight transfer to the rear tires. More negative castor means more weight transfer under wheel deflection. Less castor (more positive) means more steering thru-out the throw and more front grip over all.
I hope this is helps you ..
Old 11-29-2008, 07:52 AM   #759
P2
P2's Avatar
Trader Rating: 15 (100%+)
1. Yes, the 10* gives more turn in. It also gives you more "reactive caster".
2. No it does not get subtracted. With the 5* caster setting, you can have more static caster than the 10* setting.
3. Lowering the mounting position will stiffer the spring rate, giving a bit more steering.
There is a balancing act between qestions 1 and 2. Start with 10* setting with the little shim in front, big shim in back. If the car is too twitchy, try moving both shims to the rear. If it's still too difficult to drive, try the 5* setting with shims split.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 11-29-2008, 07:59 AM   #760
TimNJ's Avatar
Thanks! I can't wait to get this thing on the track tomorrow morning.
Old 11-29-2008, 08:05 AM   #761
Caster is adjusted with the shims. The dynamic caster block only alter the angle of the top hinge pin. Look at the car from the side. The upper arm is angled compared to the chassis when using 5 or 10 degree blocks.
The dynamic blocks change the caster under wheel bump (nose dive or rolling in corner) in this case the higher the block degree the more the caster is reduced. The dynamic blocks reduce caster when the suspension is compressed.
lower front shock mounting = softer
Tuner EM is offline   Reply With Quote
Old 11-29-2008, 08:23 AM   #762
P2
P2's Avatar
Before you do, take that wing off or lower it a lot
Old 11-29-2008, 08:35 AM   #763
TimNJ's Avatar
Yeah, I just stuck it on there to see what it would look like. Since I'm running a stock motor on a smallish track, I know I won't need it. Plus the fact that I screwed up and cut the slots on the wing way too far up. Oh well..
Old 11-30-2008, 06:37 AM   #764
nutsisneat's Avatar
Default Problem with left wheel hub
Yesterday, i wanted to build my 2nd. 12R5.
I had a problem with my left hub (#4567)
It was not possible to tighten the 2/56 screw.
I could turn and turn, but it didn't clamp.
I don't know the expression in English, but i hope you guys know what i mean.
Has anyone else had this problem?
I got the car from Tower, should i try to get a hub from there or should i
refer directly to AE?
Thanks...
nutsisneat is offline   Reply With Quote
Old 11-30-2008, 08:17 AM   #765
One or more of the associated guys are usually on here.
It is either stripped out or judt didnt get machined properly and the hole is clearenced drilled through out. They are pretty good about that sort of thing and will most likely take care of it. Problem is ... its a holiday weekend . and they are in Californico.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
