Old 11-11-2008, 07:38 PM   #676
Taz_S's Avatar
Call jake's he should have one in stock.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 11-11-2008, 08:03 PM   #677
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Thanks guys, will do.. What spur are you guys runnin with the brushless? We are doing the 13.5 bl here.. I just wanna have some gearing options that all.Its been a while since I ran a 1/12 scale..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 11-11-2008, 08:05 PM   #678
Ffejdat's Avatar
Most people for brushless 13.5 or 17.5 run a 78 or 76 tooth spur gear, any bigger spur and there is not enough room for gearing properly....
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 11-11-2008, 08:20 PM   #679
Ffejdat's Avatar
Hey all, I got a 12R5 last week, just thought I would share my findings after the first race day with it.. The kit went together very well, I thought the new front end built up very well, nice and straight and fairly slop free right out of the box, do not overtighten the front caster blocks to the mounts as you can distort them and then the caster is different left to right... shocks built up with no problem, feel good after a day of running, I did end up putting a screw through the fixed end of the side dampening shock,to hold the top deck on the standoff, as the set screw was not holding well, and the stand off threads in the tube seemed a little weak, a screw is much more secure... I could NOT build or shim the rear axle to be under legal width, and be centered in the chassis, with CRC rims, probably gonna have to cut down the left side hub's shoulder a little to get proper width and centering...
Overall the car worked well, ran it at the first round of the LSRCC Superior race, did TQ and win just barely, the track changed all day, so chased setup a little, ended up with black side springs, didn't have any green side springs, feel they would be the best there... car took a few VERY hard hits because of radio probelms, one hit was hard enough to pull the endebell off the 19t motor, and split the body, but chassis and front end held up great, overall very impressed, I have always been a T-bar car guy so it's a different feel, I think I will like it!
Old 11-12-2008, 02:28 AM   #680
Joost K.'s Avatar
I was looking at some pictures of the two Associated/Yokomo 12R5's that we all know won the worlds and what caught my eyes were the black wheels... After a closer look they were nothing like JACO or Parma wheels. I visited the website from Yokomo and there on the RC-12L4Y the same black wheels were mounted. My guess is that these are Yokomo wheels/tires since the Asso/Yokomo drivers were the only ones driving these wheels...
Now I couldn't find these wheels on the US & Japanese Yokomo site anywhere... Does anybody here know where to get these cruel looking black wheels???
Joost.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 11-12-2008, 05:13 AM   #681
sohlman's Avatar
Trader Rating: 89 (100%+)
That's Kawahara rubber, not sure about the wheels.
Steve Sohl
sohlman is offline   Reply With Quote
Old 11-12-2008, 05:30 AM   #682
Joost K.'s Avatar
Okay, anyone an idea about the wheels???
Joost.
Old 11-12-2008, 06:41 AM   #683
nrtv20's Avatar
What body's are on those cars? I like the yellow one alot!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-12-2008, 06:50 AM   #684
JLTrinity's Avatar
Naoto runs a Black Art A8c body.
Regards
JLTrinity is offline   Reply With Quote
Old 11-12-2008, 06:53 AM   #685
CypressMidWest's Avatar
CRC imports them, but they're out of stock until Nov. 20th or so.....
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 11-12-2008, 08:52 AM   #686
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Do they work on carpet as well as the asphalt?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-12-2008, 10:08 AM   #687
Joost K.'s Avatar
The body that Levanen uses is a Protoform Speed12(B) body...
Anyone a clue yet about those damn nice black wheels???
Joost.
Old 11-12-2008, 11:02 AM   #688
yokomo wheel part #'s
sp-1210-3 Rear Wheel set (6 wheels)
sp-1250-3 Front Wheel set (6 wheels)
MACHFIVE is offline   Reply With Quote
Old 11-12-2008, 11:08 AM   #689
Here are the tire combination's i can run at any given time...
Jaco tires...
Front tire choices for carpet
Pink,Magenta,Dbl Pink,Lilac or Purple
Rear Tires choices for carpet..
Pink,Magenta,Dbl pink or Yellow
My main tire choice for me is...
Double pink fronts with Magenta Rears...
Hope this helps..
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 11-12-2008, 01:27 PM   #690
Joost K.'s Avatar
Hey thanks!!!
But this means I have to glue my own tires because what I understand that these are just the rims??? Is there any info on the diameter of these rims? And any ideas on where to get these wheels??? Online stores anywhere?
Joost.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
