Old 11-10-2008, 09:46 AM   #661
Looks like it could be the Yokomo pod. Not much different... but... That's the way the former 12th scales have been aswell...
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 11-10-2008, 12:37 PM   #662
Hi all,
Thought I'd share my experience with my R5.
I'm completely new to 1/12th and bought an R5 to get started. I built it exactly as per the kit setup and did exactly 1, 8-minute race before competing in the first round of our Western Canadian series on the weekend.
I was using Jaco White rears and Black fronts, right out of the box and used a very marginal 4-cell pack that was salvaged from one of my 6-cell packs from last year. The car was extremely easy to drive (good thing given my newb status!) and was reasonably fast compared to everyone else.
In the end I managed 5th in the A Main 1/12th Stock (out of about 20 cars) so I'm extremely happy with the car. All I need now is some real batteries and more practice
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 11-10-2008, 06:22 PM   #663
Lebatek's Avatar
Send a message via AIM to Lebatek
Originally Posted by Joost K. View Post
Sean, will the new narrow hub work if you have a Slapmaster Thrust Bearing on the diff? I am thinking about getting this option since almost everything here in Holland is brushless in 12th scale but I use the Slapmaster on the diff...
Joost K.
Joost, I was running the Slapmaster on the stock pod 12R5 and it DOES NOT work on the BL pod because there was too much space between the Slapmaster bushing and the thrust bearings. You COULD space it to work, however, I used the new AE thrust cone for the BL pod WITH the Slapmaster thrust bearings and have one of the smoothest diffs I have ever built.
Cheers,
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 11-11-2008, 02:01 AM   #664
Joost K.'s Avatar
Yes, I figured something like that would happen... So you placed the BL diff cone and on that cone just the thrust-bearing? How does the outer diff bearing hold? That was something that used to be a part that was breakable due to the thrust that the cone pushed on the side of the bearing...
But I will try that, thanx for the info...
Oh, by the way...
CONGRATULATIONS TO TEAM ASSOCIATED... THE NEW 12TH SCALE WORLD CHAMPIONS!!!
Joost.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 11-11-2008, 02:09 AM   #665
corallyman's Avatar
Trader Rating: 99 (100%+)
Default AE World Champs again
Congrats to Naoto, "The New World Champion" Listening to the races and him winning the 2nd and 3rd leg he certainly deserved it. Juho gave him all he wanted though so congrats to him as well. Rick had a nice couple of B mains too.....good going guys. Now get them in Touring too.
Come on Rick!!!!
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-11-2008, 02:10 AM   #666
Three's Avatar
Donkey was wrong???? OMG !!!!!!
Electric good..........
Three is offline   Reply With Quote
Old 11-11-2008, 07:09 AM   #667
Lebatek's Avatar
You are correct. The brushless thrust cone rests on the inner race of the hub bearing, then the thrust bearing washer, the thrust bearing, the outer thrust bearing washer and the diff nut (I use the aluminum version).
I swapped out for the BL pod at the last minute before this past weekend's race, and I may eventually mess with spacing the Slapmaster, but for now it worked well with the parts described, although the side load issue still exists.
Best,
John Lebak
Old 11-11-2008, 07:26 AM   #668
CypressMidWest's Avatar
Congrats to Bob Stellflue, and the rest of the AE design team for this Worlds win. Great new car guys.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 11-11-2008, 09:16 AM   #669
What tire compound should i run on carpete its low to medium grip 13.5 class? Are bsr tires worth running and if so what compound should i run with them i know that thay call thier compound something different? tia.
white48rc is offline   Reply With Quote
Old 11-11-2008, 09:48 AM   #670
Default tyre combinations
A few choices and combinations that will all work.
1.Jaco Yellow rears/lilac fronts .Double pink also good fronts
2.Grp Grey rears/purple fronts
All of those combinations will give you a good handling car.You can fne tune from there
tellan is offline   Reply With Quote
Old 11-11-2008, 10:45 AM   #671
If you're going to be running BSR's, run white rears, and team purple fronts.
Parma Grey rears and Magenta fronts also work very well.
Old 11-11-2008, 04:57 PM   #672
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Is it just me or are most hobby shops out of stock on this car?.. Everywhere I look its the same old story. Anybody know why? Been looking into getting one..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 11-11-2008, 05:28 PM   #673
Maybell's Avatar
I want to say congrats to Bob and everyone at AE for the domination of the Worlds!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-11-2008, 05:36 PM   #674
Maybell's Avatar
Unfortunately this happens alot in this industry where something new and popular goes on backorder on and off for a while...
Im sure they will be back in stock soon
Old 11-11-2008, 06:16 PM   #675
sohlman's Avatar
Trader Rating: 89 (100%+)
Do a Google "Shopping" search...there seems to be a few hobby shops with them in stock.
Steve Sohl
sohlman is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
