Old 10-24-2008, 01:21 PM   #646
AE-Reedy
Originally Posted by Apex View Post
Thanks Sean.
What about the T-Bar Conversion Kit? Has the pod been centered for BL as well?
No we haven't discussed those parts yet, there doesn't seem to be that much interest in the t-bar. If demand dictates it I guess those could be done also.
Sean Cochran is offline   Reply With Quote
Old 10-25-2008, 03:11 AM   #647
Joost K.'s Avatar
Originally Posted by Sean Cochran View Post
These are the parts you need to make the "brushless" pod.
8511 -10R5 lower plate
8512 -10R5 upper plate
4608 -12R5 diff hub narrow
4609 -12R5 thrust cone
The motor plate is repositioned on the graphite pieces to change the weight balance of the pod. The hub and cone are needed to keep the rear width legal.
Sean, will the new narrow hub work if you have a Slapmaster Thrust Bearing on the diff? I am thinking about getting this option since almost everything here in Holland is brushless in 12th scale but I use the Slapmaster on the diff...
Joost K.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 10-25-2008, 01:30 PM   #648
AE-Reedy
Joost K.
I don't know anything about the Slapmaster part so I can't say. The hub is shorter so more axle protrudes from the bearing. If you have some way of taking up the extra space I guess it won't be a problem. The hub is approx. 2.5mm narrower than the original.
Old 10-25-2008, 01:38 PM   #649
hairy's Avatar
yes the slapmaster will work without shimming
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 10-26-2008, 10:10 AM   #650
Joost K.'s Avatar
Okay, and you know this from your own experience I guess???
In that case I think I will go for this option if it balances the rear pod better with the use of brushless motors...
I have ran the R5 now for several times on our brand new indoor carpet track and all I can say is that it is a great car to drive!!! Very stable right out of the box. We are now testing with different set-ups what works best but we are very pleases with the car in general...
Joost K.
Old 10-27-2008, 06:20 PM   #651
P2
P2's Avatar
Trader Rating: 15 (100%+)
Sean,
Are you talking about these holes?
Thx!
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 10-27-2008, 07:26 PM   #652
AE-Reedy
Originally Posted by P2 View Post
Sean,
Thx!
Actually it would be the middle ones. I forgot there are 3 sets of holes in that servo saver. You might be able to run the balls in the lower holes if you put the ball studs out the front of the saver. I run my servo all the way forward and have my ball studs out the back side.
Old 10-28-2008, 03:08 AM   #653
I think it will only need a new bottom pod plate, the other parts already exist.
Put me down for one please!
reynard55 is offline   Reply With Quote
Old 11-01-2008, 03:13 PM   #654
Anyone know when we might see the 12R5 in stores? I've been looking around, and no one seems to have them available. I would really like to get one to start the indoor carpet season. Also, I want to run brushless, so I will need the four conversion parts that were referred to earlier in this thread. Are they going to be readily available soon?? Any insight would be appreciated.
Thanks.
dpsguy is offline   Reply With Quote
Old 11-01-2008, 03:24 PM   #655
Maybell's Avatar
Thanks.
The major vendors show them on backorder...so I recommend having your local store put one on order for you...they show that they will be back in stock this month...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-01-2008, 09:10 PM   #656
corallyman's Avatar
Trader Rating: 97 (100%+)
Joost K.
Joost,
I suggest you ask Brian that question direct, He is a friend of mine but I don't know the answer directly. He posts alot in the 12th scale thread. His username is Slapmaster6000.
I do know he is making some parts for his car similar to what your talking about.
Steve
Sorry to interupt your thread Sean and AE.
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-10-2008, 04:57 AM   #657
sohlman's Avatar
Trader Rating: 88 (100%+)
Maybe another rear pod. Notice the different bulkhead.
http://events.redrc.net/wp-content/g...associated.jpg
Steve Sohl
sohlman is offline   Reply With Quote
Old 11-10-2008, 07:03 AM   #658
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
I think those are the pod plates off of the 10R5. They are centered for BL motors.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-10-2008, 07:13 AM   #659
Joost K.'s Avatar
Indeed, it looks different...
Joost.
Old 11-10-2008, 07:43 AM   #660
sohlman's Avatar
Look closely, the bottom of the left bulkhead actually hangs out past the lower pod plate in the back.
Steve Sohl
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
