Old 09-24-2008, 12:11 AM   #586
Is the R5 T bar conversion kit (#4685) available anywhere?
I cant find any online
reynard55 is offline   Reply With Quote
Old 09-24-2008, 03:11 PM   #587
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
http://www.ampdraw.com/browse.php?ty...=12r5&6cbd924e
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 09-24-2008, 05:07 PM   #588
RCSteve93's Avatar
Originally Posted by David Galdo View Post
These are some crazy looking decals...
http://www.ampdraw.com/product.php?a...productid=8007
RCSteve93 is offline   Reply With Quote
Old 09-24-2008, 05:11 PM   #589
racingboy14's Avatar
Trader Rating: 25 (96%+)
I want those decals on my cars!
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 09-25-2008, 03:13 PM   #590
Default Lifting Roll Centre
Just wondering has anyone had a go at raising the roll centre on the R5?
mark barford is offline   Reply With Quote
Old 09-25-2008, 09:06 PM   #591
EEChris's Avatar
Trader Rating: 21 (100%+)
Battery Question:
Do current LiPo saddle packs fit this car? Thanks in advance.
Chris Ibarra
EEChris is offline   Reply With Quote
Old 09-26-2008, 02:46 AM   #592
Joost K.'s Avatar
NO!
Straight out the box it is made for 4cell NiMH only!!!
There is still no good alternative in batteries for 12th scale. All the official races are with 4cell NiMH and that is still how they make the chassis...
Joost K.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 09-26-2008, 09:17 PM   #593
EEChris's Avatar
Originally Posted by Joost K. View Post
NO!
Joost K.
Thanks Joost K for the reply. I just may jump into 12th anyway with this car.
Chris Ibarra
Old 09-27-2008, 01:29 AM   #594
Joost K.'s Avatar
Offcoarse you will
12th scale is one of the most exiting RC classes in the world! Great speeds & great fun!
No need to let a couple of NiMH cells stand in your way of doing it. After all, there are a lot of bad stories about NiMH cells but also al lot of good ones you never hear! I personally never had any problems with the cells. Just treat them right and they will be good for you too...
Have FUN!!!
Old 09-28-2008, 12:25 AM   #595
Default Question about ride height
Hello all,
I'm brand new to 1/12th (I've raced Taxi Cabs and offroad a bit) and I picked up an RC12R5 last week as the local club here is starting to see a lot of interest in 1/12th.
I understand how to change ride height at the front using the supplied shims to go under the front arm mounts but how does one change rear ride height? Can it only be accomplished via truing the tires down? I tried flipping the rear bearing blocks in the side plates of the rear pod but that got me slammed right to the ground with virtually zero ride height with out-of-the-box Jaco tires! I know on my F103RM (F1 chassis) I have a series of bearing blocks with the bearing holes in various positions that when flipped and flopped allows for a variety of axel heights but my RC12 only came with the one set...is this correct? Currently with out-of-box Jaco's I have a front height of 4mm and a rear height of 5.5mm.
Thanks in advance for any help you could give me!
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 09-28-2008, 12:31 AM   #596
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Hyper Mike, at the bottom is what you want: http://www.teamirsrc.com/podplates.html
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-28-2008, 06:08 AM   #597
Joost K.'s Avatar
That's an unfortunate miss in the R5 kit. There is only one bearing block for the rear end. If you are new to 12th scale and you have never owned another 12th scale kit you will have to buy a set of bearing blocks from either Associated, IRS or another brand that uses the same blocks. I was fortunate to have a set from Associated that came with the RC12L4. The IRS set is probably the best way to go because with that set you can set the rear ride height the most accurate...
It is also still on my wish list...
Joost.
Old 09-28-2008, 07:20 PM   #598
t4m1y4niac's Avatar
what is the good of using T-bar on 12R5?????
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 09-28-2008, 07:29 PM   #599
t4m1y4niac's Avatar
Originally Posted by JoelV View Post
Taken from my experience w/ the Speedmerchant. To see how close you are to shimming, you can take a wrench and hold it square on the inside of the rear tire and compare the distances to the tweak spring screws. This isn't really measurable but you'll be able to see right off the bat if you are completely off or not.
ou got PM...
Old 09-28-2008, 10:02 PM   #600
Thanks Rezenclowd and Joost! That is what I figured as it didn't make sense to me to just have the one bearing block. I'll pick some up ASAP.
Thanks,
Mike
Mike
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
