Old 09-16-2008, 11:44 AM   #541
Originally Posted by rezenclowd3 View Post
#102374 WA-CB 1/12 Scale Universal (Except Corally)
Thanks man!
RC12 is offline   Reply With Quote
Old 09-16-2008, 04:01 PM   #542
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
David, you are all ways welcome to run with us down here in SA.
CarlosG. is offline   Reply With Quote
Old 09-16-2008, 04:24 PM   #543
Default Building Tips?
Hi, getting back into 12th scale racing since a new carpet track is opening locally. Last 12th scale I ran was an AYK 86J (does anyone remember that?) and clearly things have progressed a good amount in 20 years. I have been on and off nitro, 18th scale, and 10th scale touring in the past few years, but it looks like I need to re-learn 12th scale to get back in the game.
Current setup is a KO 949, Novak GTX (i pulled this from my TC) and a variety of stock brushed motors. I'm going to do some rollout calculations to figure ratios.
Track will be indoor carpet, med grip. can anyone point me to building tips for this car, and a good starting point for the aforementioned track? It is not a very technical track for now.
Thanks much!
zaiguy is offline   Reply With Quote
Old 09-16-2008, 04:48 PM   #544
AE-Reedy
Thanks much!
I've put together a couple of cars and I think most everything should go together with no problems. The only thing I can find that is off in the instruction manual is the rear axle spacing. I would recommend measuring the rear wheel to the center of the car and adjust the shims accordingly. I would tell you exactly what it should be but I can't remember at the moment. I think you need about .060" extra shims on the diff side of the axle. let me know if you have any other questions.
Sean Cochran is offline   Reply With Quote
Old 09-16-2008, 06:49 PM   #545
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Sean, that sounds about right. I would think AE would make that unnecessary, do you think that is a weight distribution decision? As it stands with my 10.5 Novak brushless motor, the pod is NOT balanced. No biggie as the pod shouldn't roll anyway from my VERY limited understanding of 12th scale tuning.
Any tips for taping the batteries in? Or just remove the front of the side links temporarily?
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-16-2008, 08:13 PM   #546
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Rezencloud3:: I know it is sticky tough, but I don't remove anything when routing the tape. Solvang?!? I will be visiting soon. Lived not far from there for six years at VAFB.
Carlos:: I am planning a road trip before it gets too cold or rains every weekend. If you and Paul venture this way you have a place to stay.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 09-16-2008, 08:24 PM   #547
David, thanks. Hey, if your going to visit Solvang, by any chance are you going to visit Santa Barbara also? (30miles away) Do you run offroad? If so you should check out the Eilings Park Raceway if you get the chance. I used to run offroad ALL the time there, and its really bitchin now! Heres the info:
http://www.elingsraceway.com/
Masters of the Dirt - Santa Barbara
Joey Christiansen from "The Dirt" built it.
Used to have a better website, but things change....
Old 09-16-2008, 08:35 PM   #548
Now see, today you can't find many tracks made like that. In the mid to late eighties when I had the gold tub, we had a similar track like that up in SLO-town and Santa Maria. Soil conditions is awesome!
V-Dezign 4.0
Old 09-17-2008, 06:05 PM   #549
RCSteve93's Avatar
The shimming is not a balance issue... more like a axle width issue.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 09-17-2008, 06:31 PM   #550
I sure hope AE fixes the shimming issue with a longer left side diff hub.
Old 09-17-2008, 07:39 PM   #551
CarlosG.'s Avatar
Paul is planning a trip up their for the state fair with his wife. One of the other racers and I might be going up sometime probably after october.
Old 09-17-2008, 11:24 PM   #552
Ah, but he is most likely not racing... I will hopefully venture your way during October.
As for the axle shimming... I know from past kits, none where perfect. That is why it is in best interest to have varied shims. I don't feel there is anything with the present axle hindering the performance of the R5. My understanding is the manual is not accurate for the build. I don't recall looking at the manual while building this kit, but did prior to the build. I just knew to use a caliper to check the axle for equal left and right length. So after reading the recent posts about this shimming issue, I had to read the manual again to see the error. Still, it did not seem a bit odd to add a few more shims on one side and not the other.
V-Dezign 4.0
Old 09-18-2008, 03:35 AM   #553
RCSteve93's Avatar
Shims are not an issue. Due to various offsets of rear tires it is necessary. My DB12R needs 3 1/32" shims each side. I need one extra each side when I run Jaco tires because I normally run Parmas.
rm -rf /windows
Old 09-18-2008, 09:00 AM   #554
Yes, but it would be nice to use the same # of shims on each side, instead of +.060 inches on the diff side. I understand that there are different offset tires, and different widths that people want to use.
Old 09-18-2008, 09:34 AM   #555
Does anyone know a good rollout for this car on a medium grip carpet trak, medium size? Motors are LRP X11 8,5 or 10,5, both with 12,5mm rotor.
potloodslijper is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
