Old 09-07-2008, 06:07 PM   #496
noline's Avatar
Hey guy's I have a gearing question Im racing on a 50 X 25 carpet track with a 1.75 rear tire how should i gear a 17.5
noline is offline   Reply With Quote
Old 09-07-2008, 06:54 PM   #497
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Start off with a 39 tooth pinion and 76 spur gear. Check your motor temp and don't let it get above 150 degrees. Continue to check tire diameter and motor temp. For starters, gear between 120 to 150 degrees with the motor. Take risks later. Someone here can post a link for a rollout chart. My rollout chart is on my phone.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 09-07-2008, 09:19 PM   #498
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Heres a link I got off the 12th scale thread for the BMI DB12r thread for the gear chart: http://www.rctech.net/forum/4792583-post5349.html
CarlosG. is offline   Reply With Quote
Old 09-08-2008, 02:21 AM   #499
hello , i pretty new to this hobby , as my main thing is 1/5th scale racing .
But for the winter i ordered an RC12R5 with the following stuff :
JACO front and rear prism tyres ( double pink and pink ones )
LRP 10.5 stock spec motor
29 and 30 pinions ( to go with the stock 96 spur , motor has 39mm rollout according to lrp website )
protoform 12 body
futaba 9650 servo
and some spares ( axles , front arms etc )
anyone who has suggestions for this setup feel free to reply
t.h.o.m.a.s. is offline   Reply With Quote
Old 09-08-2008, 04:00 AM   #500
All is good except you will probably need a smaller spur gear (88t?) You will need to aim for a gear ratio of around 55mm/rev. See posts above for a gear chart. Have Fun!
mark barford is offline   Reply With Quote
Old 09-08-2008, 09:59 AM   #501
Hello Guys,
Posted this in the 1/12 Forum but thought I might also get help here... hope thats ok...
Newb to 12scale so I need some help
Here are my setup...
Kit: AE 12R5
Spur: Stock Spur
Tires: Pink/D.Pink JACO
ESC: LRP Sphere Comp.
Motor: 13.5 Orion/10.5 Orion
Track: Indoor Asphalt Med/High Grip
What PINION to use for..
Motor 13.5 Orion = ?? Pinion
Motor 10.5 Orion = ?? Pinion
Any help or suggestion would be really appreciated! Thanks in advance!!
RC12 is offline   Reply With Quote
Old 09-09-2008, 01:41 PM   #502
Originally Posted by RC12 View Post
Hello Guys,
Kit: AE 12R5
Spur: Stock Spur
Also, did I choose the right tires? R=Pink F=D.Pink?
Anyone? Help please?
Old 09-09-2008, 01:58 PM   #503
overflow's Avatar
Hello Guys,
Kit: AE 12R5
Spur: Stock Spur
i would go novaks site, im sure that the roll out for the novak motors is pretty close to the orions. and check the sugested roll out for the motors.
http://www.teamnovak.com/tech_info/b...r_gearing.html
then go to gearchart.com and figure out your roll out. that should let you know what pinion to use.
i use pink and dbl pinks on mine for asphalt and they work pretty well.
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 09-09-2008, 02:37 PM   #504
timmay70's Avatar
In on of Jack Rimmer's posts he noted that d.pink f/r is pretty standard for asphalt for stock and mod. I don't run asphalt or know your track size, both of these can affect ideal rollout.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 09-09-2008, 03:43 PM   #505
nutsisneat's Avatar
Is double-pink rear the 2-stage tire? I don't find this tire on
Jacos site. Does anyone have the item# for the rears?
nutsisneat is offline   Reply With Quote
Old 09-09-2008, 08:38 PM   #506
Thank you very much sir! Will do that!
Old 09-09-2008, 09:54 PM   #507
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Jacos double pink is not a 2 stage tire.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-10-2008, 08:41 AM   #508
Default Setting the tweak on a R5?
How are you guys setting the tweak on your R5'S? Tweak station, coin trick, withor without the side damper atached?
Also how much pre tension are you running on your side springs? Here in the U.K using JtG type additive the black side springs (i.e soft) are being used by everybody.
Car is great, I am loving the corner speed!
Old 09-12-2008, 06:05 PM   #509
Default servo saver??
hey guys....
Anyone know which type of servo the saver that comes with the kit is actually used for? The splines don't seem to fit my Futaba 9650. Suggestions for the correct servo for the job?
BulletMaster is offline   Reply With Quote
Old 09-12-2008, 06:38 PM   #510
AE-Reedy
Originally Posted by BulletMaster View Post
hey guys....
Airtronics, JR, KO. Unfortunately Futaba requires a different servo saver.
Sean Cochran is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
