Old 08-13-2008, 06:36 PM   #451
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
[QUOTE=racing_jason;4737140where is a place to get ride height adjustments shims from?[/QUOTE]
+1
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 08-15-2008, 03:50 PM   #452
WIITA's Avatar
Trader Rating: 41 (100%+)
Default LIKEY??
HEY GUYS! JUST LOOKING AT THIS CAR AND THE BMI DB12R AND I AM STUCK BETWEEN WHAT ONE TO GET. HELP ME OUT. HOW DO YOU LIKE THIS CAR SO FAR?
WIITA is offline   Reply With Quote
Old 08-15-2008, 06:06 PM   #453
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Trust me when i tell you .... you want to be buying the 12R5
wallstreet is offline   Reply With Quote
Old 08-15-2008, 07:08 PM   #454
sportpak's Avatar
Trader Rating: 26 (100%+)
Originally Posted by racing_jason View Post
what is a good starting point for carpet racing with this car, also where is a place to get ride height adjustments shims from?
IRS makes a nice set. IRS quality is second to none.
All the way to the bottom of the page.
http://www.teamirsrc.com/podplates.html
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 08-17-2008, 08:49 PM   #455
overflow's Avatar
Ran the car for the first time yesterday at bending corners in orange ca on the asphalt track. and all i have to say is wow, it worked nice!
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 08-17-2008, 08:57 PM   #456
wallstreet's Avatar
This car is race ready...... Everything you need is in the kit..
fine tuning items such as different center springs and side springs are required along with the ride height adjusters for the rear only.. The kit comes with aluminum spacers to raise and lower the front end
Old 08-19-2008, 11:31 AM   #457
racing_jason's Avatar
hey guys i was just looking for an answer on how to adjust the droop on the car people talk about it but i have no idea how to adjust it on any car. thank you for your help!
Jason Hunt
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 08-19-2008, 11:55 AM   #458
EricF's Avatar
racing_jason-
rear pod droop is adjusted by turning the ball ends on the center shock.
to adjust it on the front you would add or remove shims from the kingpin.
E
EricF is offline   Reply With Quote
Old 08-19-2008, 11:55 AM   #459
Trips's Avatar
Trader Rating: 16 (100%+)
On a 1/12 chassis, you adjust droop by lengthening or shortening the center shock. Make small adjustments, a little can have a big effect...
MARSHAL!!
Trips is offline   Reply With Quote
Old 08-19-2008, 02:04 PM   #460
so if a person says they are running .5mm of droop that means the ball end of the schock is a half milimeter longer then the stock setting?
Old 08-19-2008, 02:31 PM   #461
beta bob's Avatar
Trader Rating: 2 (75%+)
Where would i get the center and side springs and would i need them for this car?
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 08-19-2008, 03:27 PM   #462
AE-Reedy
I can't speak for others but I lay a straight edge along the bottom of the chassis and rear pod and measure the gap from the ruler to the chassis.
You need to make sure the shock is fully extended when you measure.
Sean Cochran is offline   Reply With Quote
Old 08-19-2008, 05:04 PM   #463
This is from over at the DB12R thread but the way to measure droop will be the same on the 12R5 as any other car. Hope it helps:
Originally Posted by protc3 View Post
Measuring pod droop in degrees is a pain in the azz What we do is measure the ride height on a flat surface. Then we lift the car slowly from the ballstud on the pod top plate until the shock fully extends and starts to lift the car. You want to lift it until the rear wheels are just about to leave the ground and then measure your ride height at the same area. The difference between the 2 ride heights in mm will give you the droop amount.
Old 08-19-2008, 06:10 PM   #464
mkdut's Avatar
Trader Rating: 19 (100%+)
Essentially the same method but I set the main chassis on 10mm blocks and let the pod hang down and measure the height. Droop is then 10 minus the height of the rear of the pod.
mkdut is offline   Reply With Quote
Old 08-19-2008, 10:51 PM   #465
so it is technicaly in a way of internal limiting?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
