Old 07-24-2008, 08:18 AM   #406
Hello, are this tools you need to build the 12R5?
Allen Drivers:
- .050 Allen Wrench
- 1/16" Allen Wrench
- 3/32" Allen Wrench
- 2.5mm Allen Wrench
Nut Drivers:
- 3/16" Nut Driver
- 1/4" Nut Driver
- 11/32" Nut Driver
Phillips Screw Driver << Still needed on an R5?
Any other wrench and/or driver needed?
Thanks in advance!!
RC12 is offline   Reply With Quote
Old 07-24-2008, 08:26 AM   #407
Rob Burns's Avatar
One of the racers at my local track said the car was metric apart from the rear axle so you might need metric drivers.
Rob Burns is offline   Reply With Quote
Old 07-24-2008, 08:38 AM   #408
Uh oh!
Anyone here can help with the tools? Reason is I want to have those tools on hand when I buy the kit.
I'm just curious, do 12R5 owners visit any other forum with 12R5 thread? It's just that this thread sleeps and have to flip pages to go to this thread or is it this kit is not popular? Just curious and not looking for flames...
Thanks for the info Rob!
Old 07-24-2008, 08:42 AM   #409
overflow's Avatar
Originally Posted by RC12 View Post
Uh oh!
the kit comes with the allens. so i wouldnt worry to much about the tools.
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 07-24-2008, 08:44 AM   #410
overflow's Avatar
Originally Posted by ammo View Post
I believe the popular brands are KO and Futaba
personally, i use the 9257, it's fast enough to take up the job of mini helicopter's tail control so i suppose it's plenty fast for the steering
i cant find 9257's anywhere for sale. anyone have any other models that they prefer? the hitec one i had for my l4 is not wide enough. what fits the mount points?
Dennis Vice
Old 07-24-2008, 09:45 AM   #411
Robert_K's Avatar
I'm using Futaba's in my R5. 9650 digital and metal gears, but quit heavy, and 9602, plastic gears.
I had an Sanwa, 95xxx these are good, but hard to get.
Use Futaba the're great... Ko's are sometimes nog that good and Hitec... don't even think about buying the, they don't go back to the centerpoint that wel...
goodluck
Greetings Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 07-24-2008, 11:46 AM   #412
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Uh oh!
The tools I recently bought cheap are allen drivers from Dynamite::
3.0mm
2.5mm
2.0mm
1.5mm
3/32
1/16
I also use the Futaba 9650, great servo!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 07-24-2008, 11:53 AM   #413
Trips's Avatar
Trader Rating: 16 (100%+)
I like the 9257 for the speed, but I'm a little concerned about the 17.8oz. torque rating... I wonder if that's really enough for the job. I might have to try one tho...
MARSHAL!!
Trips is offline   Reply With Quote
Old 07-24-2008, 11:59 AM   #414
RC MARKET's Avatar
Ko Propo PDS951 ICS
RC MARKET is offline   Reply With Quote
Old 07-24-2008, 09:50 PM   #415
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Futaba 9602 Analog servo
Futaba 9650 Digital servo
KO 949 Digital servo
KO 951 Digital servo
All good servos, just choose which fits your budget or your personal preference.
CarlosG. is offline   Reply With Quote
Old 07-24-2008, 11:00 PM   #416
overflow's Avatar
thanks guys for all the server recommendations. Should be picking up a 9650 this weekend.
Dennis Vice
Old 07-25-2008, 06:27 AM   #417
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Greetings Robert
my futaba 9650 is digital with plastic gears, while 9602 is analog with metal gears!
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 07-26-2008, 06:06 AM   #418
martymiller's Avatar
Has anyone figured out what size of allen wrench the side links take.
It does not match anything I have or anything in the kit.
martymiller is offline   Reply With Quote
Old 07-26-2008, 08:23 AM   #419
Trips's Avatar
I used my .050 for the side links. It was a little loose, but no problem because you don't actually make those screws tight, you just get them to touch and stop there.
MARSHAL!!
Old 07-27-2008, 06:49 PM   #420
I have what will sound like a very stupid question.
The rear axle spacers are 3 on one side and 3 on the other. So I measured from hub to center hole on both sides, and it appears to off. I would think that by now a kit would at least have you put the correct spacers on the correct side to center the rear axle.
Or is there some magical balance thing, where the offset axle makes the rear pod balanced.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
