Old 06-26-2008, 08:30 PM   #376
Originally Posted by eflite300 View Post
I was wonderning if any of you run the Nats we just had with a BL and what was your spur and pinon ???
anyone???
eflite300 is offline   Reply With Quote
Old 06-26-2008, 09:03 PM   #377
Originally Posted by timmay70 View Post
You can try and maybe get lucky... and you can also turn your $85+ motor and $150+ speed controller into a charred mess, your choice. All it takes is a pair of $15 plastic calipers and a chart that was already offered to you along with about 1 minute max. No computer required. There is no one at our track that takes a computer to the track for the purpose of calculating anything.
btw, good luck. From the sounds of it, you will need it.
Why do you make assumptions as to what would happen to my equipment? Didnt I just mention at the beggining of this that I would ask somebody what they were geared at and go from there? And observe!!! Why dont you read before you reply. Ill take my 5th grade edumacation and will be having fun racing. Go immerse yourself in more rollout calculations.
This is fun I cannot believe how many people have responded to my rant!
Im gonna start a no rollout revolution!!!!!
LOL!! By the way Timmay speaking of me needing luck...I got lucky last night Did you?!
Bubonic-X is online now   Reply With Quote
Old 06-26-2008, 09:14 PM   #378
GreaseMonkey's Avatar
anyone???
I thought you were kidding after all the previous posts arguing about spur and pinions and how gearing the same as someone else is useless unless you are running the same diameter tyres as them.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 06-26-2008, 09:24 PM   #379
odpurple's Avatar
Originally Posted by hanulec View Post
This is one of the best explainations I've seen of roll-out yet.
http://www.rctech.net/forum/showpost...ostcount=28014
Damn straight. That's authored by Scottrick, he's real smart!
Even if you think you understand rollout you should read this.
Originally Posted by nutsisneat View Post
I'd like to know a roll out on a medium size, technical carpet track.
I will run either a 5.5 or a 4.5 Novak motor with 4 cell.
2nd. question:
Are there any other ride height adjusters available besides the one that are
included in the kit? number?
If you want to get silly with rear ride height adjustment you can get the Xenon ride height adjusters, which go in .25mm increments. They are real costy, though
anyone???
Sorry, but you have to ask a complete question. 17.5? 13.5? mod?
All the guys there that I know that ran 17.5 rolled out at between 80 and 90mm. You pretty much have to use a 76 tooth spur (or close to that) to achieve those high numbers. In the main I ran 49/76 with a 44mm tire. Thats 89mm rollout
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 06-27-2008, 04:12 AM   #380
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Originally Posted by odpurple View Post
please post what motor you are running and the size/type of track
Med size asphalt technical track, 19 turn brushed.
Thanks.
dirtdustingdavo is offline   Reply With Quote
Old 06-27-2008, 10:57 AM   #381
odpurple's Avatar
Thanks.
Different brands of 19t require different gearing. The most popular brushed 19 around here is the Komodo which likes a rollout around 48mm. Most of the other motors gear higher, Reedys run in the 50s and Checkpoint $ higher than Reedy
Old 06-27-2008, 11:35 AM   #382
nashrcracer's Avatar
R/C Tech Charter Subscriber
for my novak 17.5 I ran a 98.4mm in "A" 3 at the nats and it slowed down 2 tenths. forgot to temp it but it was hot. that's a 3.87 for us yanks. that was also at the hottest part of the day. the best run I ran in "A" 1 which was second fastest in the "A"s at the nats behind Kyle and faster then stelfule, the roll was 101.8mm or 4.01" and the motor came off at 135F (sorry everybody else you'll have to convert that to C) but that was about 11am so the track was cool and the sun hadn't really come out. I think the 98mm is prabably the best for a track with 150' or 45m straight. I run on a smaller track locally 100' or 30m and I run a 96mm or so. it really depends on the infield for some tracks. I ran a 89mm or 3.5" at the carpet nats and was only a few tenths off the fast guys with my 17.5 on a 85' or 25m track. I'm not fast but I bet if someone fast was driving my car they would be with that rollout.
tell me how this works?
http://www.rc50.com/media/roll12.htm
or this you can print out and take to the track.
http://www.rc50.com/media/roll12.pdf
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 06-27-2008, 04:51 PM   #383
OK that gives me somewhere to start, At this stage I haven't run anything in the car as its still being set up. I was also thinking as this is my first venture into 1/12th it might be a good idea to start with a CO27 and get the feel for it. Any tips and roll out start points for this motor? I think the straight is around 35-45 meters give or take.
Old 06-28-2008, 05:58 AM   #384
You should start the CO27 (with most brush/spring combos) around 48mm rollout and adjust from there.
We ran the Komodo 19T around 52mm rollout.
Larry Brown is offline   Reply With Quote
Old 07-04-2008, 05:12 AM   #385
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
OK, what page is the carpet setup... hopefully I will set my car on carpet later today and race tomorrow. Who's stocking spares for this kit?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 07-06-2008, 01:28 PM   #386
nutsisneat's Avatar
Is it possible that the Parma EXP Speed 8 won't fit on this car?
The body "scratches" in the area of the rear pod when i mount is as
low as a Protoform Speed 12.
Will the Zytek fit?
nutsisneat is offline   Reply With Quote
Old 07-07-2008, 03:57 PM   #387
Trips's Avatar
Trader Rating: 16 (100%+)
Will the Zytek fit?
Mine definitely rubs with the Parma Speed 8. It's the front edge of the upper pod plate at the side shock attachment point that hits the body. The Protoform Speed 12 clears, and the Parma Speed 8 HD seems to clear as well.
I haven't tried the Zytek.
I have an idea for a fix to this (I really like the Speed 8, this issue bugs me)
I'll post pictures if it works out.
MARSHAL!!
Trips is offline   Reply With Quote
Old 07-07-2008, 06:52 PM   #388
Trader Rating: 25 (100%+)
Default 12R5
This is the best 1/12 I have ever owned. I do need more steering for mod. I am running stock set up with Parma Magenta, Coral's, any help?
fred kellner is offline   Reply With Quote
Old 07-08-2008, 01:50 PM   #389
Trips's Avatar
fred, try a stiffer side spring on the car, I noticed the kit ones are a bit on the soft side compared to most of the other link cars out there. I'm going with a set of the Speedmerchant .021 side springs this weekend. I've also got a set of .023 to try if I still want more... If the car starts to feel darty you might want to go up to 25 wt. oil in the side damper to calm it down a bit...
MARSHAL!!
Old 07-08-2008, 11:47 PM   #390
I found a setup I can use for this weekend. I will try different tires to tighten-it-up more...
I ended up using a red center spring and red CRC side springs. Hole two on the shock tower. 27-1/2 Losi shock oil in the side dampener. Stock front springs. 3mm front/back ride height with a tiny bit of sag in the center. And the car was stuck with a 17.5, Lilac/Pink tires.
Will experiment with other shores and a Protoform 12 body...
V-Dezign 4.0
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
