Old 08-09-2012, 07:03 AM   #3736
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by gixx View Post
Hey guys,
I really want to get into 1/12 scale racing and currently looking at the r5.1. I happened to have a standard size jr mp80g servo which was meant for heli tail control and is only rated for 4.8v. Can this servo be used in the r5.1?
Thanks for your help.
Gixx
It's heavy and the size is a bit odd, but the specs are fine
Futaba 9650 is most common
Here are a list of a few other used
12th Scale Racing is Alive and Well in So Cal
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-09-2012, 06:44 PM   #3737
Thanks RedBull
gixx is offline   Reply With Quote
Old 08-09-2012, 07:00 PM   #3738
I am putting one together and want to start out with a 21.5 or a 25.5. I am new to rc also hence the reason for slow motors. What would be a good roll out to be at? I looked at the charts and it all has to do with tires do I start with a 72 or higher spur?
MikeFrazer is offline   Reply With Quote
Old 08-09-2012, 07:24 PM   #3739
What size is your track
At our local carpet hang out 90x45' area
17.5 blinky is Wide open all the way around @ 95 to 100mm roll
If your track is half that size, I image a 21.5 might feel the same ?
The speed of the motor won't be a learning curve at all
However, adjusting to the cornering speed of a 12th scale takes some getting used too, if coming from Sedans, or Off-Road
72t spur is correct
Old 08-09-2012, 07:43 PM   #3740
I want to say its 100x50 outdoor concrete I have been doing off road and 17.5 touring car but I am thinking about dropping down to vta to learn to drive better.
Old 08-09-2012, 08:52 PM   #3741
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Mike go with 17.5 for 1/12... anything else will be a pig. It will more than likely be the motor for Stock 1/12 at the Hangar this season and that is the place to race 1/12.. Remember we are only running 1S so it is slower than a TC..
Check out Gear Chart..
http://gearchart.com/index.cfm?fuseaction=chart.create
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\Schelle
Logi Maker is offline   Reply With Quote
Old 08-09-2012, 10:12 PM   #3742
Kyle I would like to run it there but I will not be in the area ship is deploying again. I want to get it ready before I leave at the end of the month and run it at brcr on road track.
Old 08-10-2012, 12:34 AM   #3743
So I'm new to 1/12th racing. I swapped my spare F1 car for a RC12r5.
Just needed a servo and a few small bits.
I have the small bits but not the servo it seems. I just assumed that my low profile Savox servo from my Pro10 would fit.
It's pretty close.
Has anyone just drilled another hole a wee bit over to fit a normal sized servo?
I just don't want to fork out for aother servo I might not use if I don't like 1/12.
FST4RD is offline   Reply With Quote
Old 08-10-2012, 04:48 AM   #3744
Chaz955i's Avatar
It's pretty close.
I run a JR3650 which doesn't line up with the stock mounts. I just servo tape the servo in the position I want it and then run a thin bead of shoe goo around the perimiter. The servo will stay put and is still easily removable. Not a perfect solution for everyone but a lot of people at my track do the same and I've yet to see one come loose.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 08-10-2012, 06:30 AM   #3745
Logi Maker's Avatar
Oh got ya... i would still go with 17.5 since that is going to probably be the standard for stock everywhere.... i am itching to get out there.. Sizzler this weekend and then BRCR is my new home..
You have got to run that 1/12 on the ship.. epic picture opportunities ....
Pan cars RULE!
Kyle Predmore
Old 08-10-2012, 06:34 AM   #3746
The only problem with running them on the ship is if a radar goes off and the car goes off the ship into the water lol
Old 08-11-2012, 05:24 PM   #3747
Does it matter what 1s battery I run? Should I be looking to save weight in the battery?
Old 08-13-2012, 12:51 PM   #3748
Center shock q:
In the 5.2 manual they use 5mm(2x2mm+1mm) under ballstud and the lower hole on lipo shock upmount; any reason for the steep angle?
oddski is offline   Reply With Quote
Old 08-17-2012, 10:45 PM   #3749
Default new to 1/12th
just to say what a great time i had with my rc12r5.1 at last club night been driving touring cars last 3 yrs takes a bit of practice with having foam tyres on
rc12r5.1
moggy12 is offline   Reply With Quote
Old 08-19-2012, 12:06 PM   #3750
For sale is 3 pieces of Reedy 4600 40c 3.7v lithium polymer (LiPo) batteries, ideally for 1/12th scale on-road pan cars.
If interested, please visit the listing I created here in rctech at:
Reedy 4600 40c 3.7v LiPo (3 pieces)
Thank you!
kokoyang is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
