Old 06-25-2008, 09:01 PM   #361
timmay70's Avatar
Originally Posted by Bubonic-X View Post
OK if I put my car on the track to practice with whatever size tires were on there and make sure its fast enough by OBSERVING other cars and adjusting my gearing as I had previously stated and I beat you in the main I think I proved my point. .... And I will further illustrate Mr Geek squad go get your laptop and go calculate your rollouts..Meanwhile I will be racing and having fun rather then crunching numbers thinking you will get that so called magic gear ratio with so called magic edge. LOL!
Dont make fun of my 5th grade edumacation Im hurt and devastated!!!
Thank you drive thru!!!!!
I love getting you guys going ballistic over the stupidest things its so easy....Thats what makes this country so great remember that
Signed
Laughing all the way to the hobby shop and the finish line...BOO YA!!!!!!
You can try and maybe get lucky... and you can also turn your $85+ motor and $150+ speed controller into a charred mess, your choice. All it takes is a pair of $15 plastic calipers and a chart that was already offered to you along with about 1 minute max. No computer required. There is no one at our track that takes a computer to the track for the purpose of calculating anything.
btw, good luck. From the sounds of it, you will need it.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 06-25-2008, 09:11 PM   #362
Is there a website teaching how to compute roll out?
RC12 is offline   Reply With Quote
Old 06-25-2008, 09:20 PM   #363
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
You can use this following link to a gear ratio program to plug in numbers or ask/PM one of the guys that commented of using a spreadsheet to e-mail it to you.
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
I have used the rollout method combined with motor temping to reach my goal.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 06-25-2008, 09:25 PM   #364
theisgroup's Avatar
excel spreadsheet
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-25-2008, 09:32 PM   #365
Originally Posted by theisgroup View Post
excel spreadsheet
Thank you sir! I'll try to figure how it applies Thanks again!
Old 06-26-2008, 12:37 AM   #366
odpurple's Avatar
Its well established that there are numerous ways to calculate roll out. For me those PDF files and spread sheets are never where I want them so here's my method. I have a cheapo calculator in my box with the formula "Dx3.14xP/S" written in sharpie across the front. D=tire diameter, 3.14 is Pi, P=pinion and S=spur. tire dia x Pi x pinion teeth divided by spur teeth=roll-out
You can spend all day chasing the right gear ratio as your tires wear or you can just figure it out in this simple manner.
If you are math challenged then just run rubber tire touring car with the masses
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 06-26-2008, 02:42 AM   #367
You're right, we do go ballistic, especially when things really are that stupid.
And, as someone who doesn't live in your country, I'm not convinced you have the last bit right, either...
SlowerOne is offline   Reply With Quote
Old 06-26-2008, 04:59 AM   #368
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
excel spreadsheet
Doyou have the metric version?! lol
Old 06-26-2008, 05:01 AM   #369
hanulec's Avatar
Trader Rating: 27 (100%+)
This is one of the best explainations I've seen of roll-out yet.
1/12 forum
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-26-2008, 05:15 AM   #370
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
OK I understand how to do the math on roll out but, how do I know what roll out I need? I.E I have worked out my roll out to be 38.24. Where should I aim to be?(in the 40's?) does it depend on the size of the track and how tight it is. I have been told that I should always try to achieve 1-1.
dirtdustingdavo is offline   Reply With Quote
Old 06-26-2008, 05:40 AM   #371
theisgroup's Avatar
here is the metric version. hehehehe
yang lai
Old 06-26-2008, 11:50 AM   #372
odpurple's Avatar
please post what motor you are running and the size/type of track
Old 06-26-2008, 02:06 PM   #373
nutsisneat's Avatar
I'd like to know a roll out on a medium size, technical carpet track.
I will run either a 5.5 or a 4.5 Novak motor with 4 cell.
2nd. question:
Are there any other ride height adjusters available besides the one that are
included in the kit? number?
nutsisneat is offline   Reply With Quote
Old 06-26-2008, 02:23 PM   #374
mkdut's Avatar
Trader Rating: 19 (100%+)
Originally Posted by nutsisneat View Post
2nd. question:
You can get the IRS ride height adjusters for the rear which allow you to adjust in 0.5mm increments.
mkdut is offline   Reply With Quote
Old 06-26-2008, 06:11 PM   #375
LOW ET's Avatar
Trader Rating: 96 (100%+)
for you guys that have this car, how's it working out for you? i'm looking at a rc10r5 and i'm sure it's going to run very similar to these cars.
LOW ET is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
