Old 07-15-2012, 06:47 AM   #3706
jsinclair's Avatar
I just picked up a used 5.1, im going to be running it in stock on carpet. 1/12 scale is still alive in our area. Other than rear bearings, what are Some necessary spares that i should carry.
jsinclair is offline   Reply With Quote
Old 07-15-2012, 07:28 AM   #3707
EricF's Avatar
Bearings for the diff thrust, front axle, lower front arm. Those are parts That I have managened to break, bend or wear out.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 07-15-2012, 07:28 AM   #3708
Front wheel bearings, front axles, body posts, spur gears, and spares of the front end plastics.
In the odd wreck, Ive seen guys break the rear axle... but that is typically not a problem in Stock 12th. And Ive seen a shunt bend the lateral shock shaft. But those types of wrecks are typically hard enough that you might be going home anyway with a tweaked chassis, etc.
Regardless, the above listed pieces should keep you in business on a typical race day. Of course, you want to have extra tires with you too. Chunking tires and cracking rims is often the most common issue in 12th....
JamesL_71 is offline   Reply With Quote
Old 07-15-2012, 11:04 AM   #3709
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
get a set of front turnbuckles too. they expensive but one night, i broke both an axle and one of those $8 Turnbuckles lol.
front axle shims so you can play with adjustment, but you always seem to lose them too. 1/8th eclips in case you lose them in a crash.
some of the ride height shims for the front and crc ride height adjusters for the rear.
some crc parts will interchange, but unless you have a lot of people running Xi in your group, you might be out of luck for stuff like front axles, bearings ect.
a set of associated front axle bearings will got a long way unless you hit stuff every corner.
valk is offline   Reply With Quote
Old 07-22-2012, 01:30 AM   #3710
CFR
CFR's Avatar
new rear end on the 2012 Worlds car
damper tubes & no cross damper
picture by Adrian Jefferies from the UK Team
CFR is offline   Reply With Quote
Old 07-24-2012, 06:16 PM   #3711
Trader Rating: 23 (100%+)
ok I have a question.
im getting my car this week and going to run a 17.5 and out track is about a 60 foot straight away and pretty flowing at times.
what would be a good starting point for gearing ?
acuratech is offline   Reply With Quote
Old 07-24-2012, 06:43 PM   #3712
Madulla's Avatar
Boosted or not?
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 07-25-2012, 07:42 AM   #3713
Robert_K's Avatar
That is correct. Also new front suspension under arms. The blue insert is gone. Arm looks the same, but just with a countersunk screw in it. More like the On-Point.
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 07-25-2012, 09:35 AM   #3714
Regards Robert
What about the pod? Anything moved sideways, or just a fancy new rear brace?. Got an 5.1 with inline and Speedmerchant damper tubes, only thing i miss is to move the battery to left for better weight-balance.
oddski is offline   Reply With Quote
Old 07-25-2012, 09:44 AM   #3715
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
In addition to the changes up front, I believe it's a just a carbon brace, all for improved durability
Stellflue has been testing that chassis at TQ for a while now
The proto WGT he's been working on is pretty slick too
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-25-2012, 09:56 AM   #3716
PutAwayWet's Avatar
As far as you know, are there any subtle (important) changes to the wheelbase or front track width? Or is it the same two bottom plates as the current lipo car?
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 07-25-2012, 10:32 AM   #3717
Someone from AE will have to weigh in on that
Haven't taken any measurements
And Bob doesn't like to give specifics when asked, at least until it is in production
Old 07-26-2012, 06:31 AM   #3718
for you guys this must be an easy question:
As far as I know the R5.1 is discontinued, the car is not listed on the Associated homepage. Will they bring out a new car? Seeing them at a worlds now does that mean they will still support 12 scale?
Having a look at the worlds pictures I saw many guys using steel balls in the diff (at least thats what it looks like, silver shiny balls) is there any advantage in steel balls? I thought ceramics are the way to go?
In the R5 manual there are put 8 balls in the diff. How many would you recommand for modified? Do you even use both rows (inner and outer ring to put balls in or just the inner or outer ring?)
Sorry for the stupid question I m new to 12 scale
takymo is offline   Reply With Quote
Old 07-26-2012, 07:06 AM   #3719
The R5.1 is still available, Obviously the 5.2 from the worlds will replace it at some point, soon perhaps ?
I prefer ceramic diff balls, they last a long time, and work flawlessly
There are those that prefer steel, both get the job done
Place as many diff balls as there are holes for on the outer row of holes in the spur gear
Check the 12th info center link in my sig for tons more info about 12th scale
Old 07-26-2012, 08:51 AM   #3720
Steel balls are a lot cheaper (maybe 10x). You can get 100pcs for about 10 bucks an don't have too worry, when you lose an expensive ceramic ball during rebuild.
Der Dicke is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
